'04 TL Intake Manifold question
Old Sep 17, 2013 | 08:50 PM
RBP_06_TL's Avatar
Would it be better to install the 3.7 intake manifold or have the stock manifold ported and polished and install the 3.7 Tb???
Old Sep 17, 2013 | 09:57 PM
anx1300c's Avatar
We've never had any real side by side, same day dyno comparisons between the two options, so it's tough to say for sure, but I'd guess the TL-SHAWD manifold will make a bit more power. The 7-8 lbs saved and cooler running composite are bonuses. Getting your current manifold ported would likely be cheaper, but don't forget you'll also need the P2R TB adapter to run the bigger TB on your manifold.
Also, for full benefit, you should add ported runners and a 3.5 or 4" CAI.
Old Sep 17, 2013 | 10:04 PM
thisaznboi88's Avatar
get the 3.7L manifold. its lighter, doesn't heat soak as fast either. Those 2 alone help a lot with the car. Or you can get a TL-S 3.5L im its lighter and also magnesium and use the stock TB
cycdaniel
Dec 17, 2019 10:58 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
james357
Feb 13, 2016 02:37 PM
kmarqueling
Oct 3, 2015 01:14 AM
EvilVirus
Aug 31, 2015 05:24 PM
