'04 tl
Old Oct 12, 2013 | 07:43 PM
Millerman's Avatar
5th Gear
'04 tl
He , I'm new here and just have a quick question. I used the search but after filtering through 100's of threads I figured it would be easier to just ask. I have an 04 TL with a blown transmission (auto), and I just got a good deal on a low mile 06 trans. I need to know what needs to be done to use it. I've read online anything from it won't work to it works fine and works but all sensors need to be changed out. Thanks in advance for your help.
Old Oct 12, 2013 | 11:22 PM
EvilVirus's Avatar
Is rebuild not an option?
Old Oct 13, 2013 | 12:09 AM
Millerman's Avatar
5th Gear
Rebuild or a remanufactured would be a lot more than I bought this for.
Old Oct 13, 2013 | 04:34 AM
Millerman's Avatar
5th Gear
73 views nobody knows? Someone must have done this before.
Old Oct 13, 2013 | 07:55 AM
callahan's Avatar
Could have found it in searching by now instead of waiting on someone to spoon feed you info.
Old Oct 13, 2013 | 08:01 AM
Millerman's Avatar
5th Gear
I've searched using every possible combination ie:04/06 trans swap, 04/06 auto transmission interchangeable. Couldn't find anything, that's why I asked for help. Thanks for you input though.
Old Oct 13, 2013 | 08:39 AM
EvilVirus's Avatar
Give it time OP
I know there are so many incomplete threads out there
If I find it and will let you know
Old Oct 14, 2013 | 07:48 AM
bouncer07's Avatar
It will work, not much difference.
Old Oct 14, 2013 | 08:46 AM
Millerman's Avatar
5th Gear
Thank-you. Do you know if I have to change some of the sensors or will they all plug up correctly?
