XM to Sirius...
Traveling the country
XM to Sirius...
I tried to search, but it appears it is broken.
What would it take to swap out the XM unit for a Sirius one? I want to use Sirius instead of XM and have it play through the stock headunit like the XM does currently.
It is possible?
It is possible?
HONSC1: Honda/Acura XM-to-Sirius Adapter
SiriusConnect Universal Vehicle Tuner SC-C1
So if I buy both of those that is all, if so that is cool. Is there not a way to reuse the stock XM antenna? I really would rather do that than run the Sirius antenna. If not can the antenna be mounted on the back deck or something like that?
Why would I want to pay $17.00 per month when the only reason I want Sirius is Howard and Bubba?
I have a Stiletto 2 that has a lifetime subscription I bought off of CL for $75 so I really need to swap over.
I just went out to the garage and spliced into the factory XM antenna harness and connected it to the cable I cut from my home dock and ran it to inside the center console it and it picks up great!
No I have to figure out what to do about power and something to hold the Stiletto.
I just ordered a car charger for my Stiletto and I am going to hard wire it in under the console and run the wire in the same holes and the antenna wire. No I have to figure a way to input it into the radio with out using the tape adapter.
vinnier6
01-22-2008 07:51 PM
RonnyC
12-08-2006 10:48 AM
