XM Preview Shut off - DomNav2Go
Old Dec 9, 2011 | 09:07 PM
JDECON's Avatar
So I installed the DomNav2go system to my iphone. Everything works well but the xm preview bleeds through when I play videos. Does anyone know how to get rid of it?
Old Apr 11, 2012 | 08:25 AM
losiglow's Avatar
I'd like to know this as well. I have the DROM Audio unit which works in the same way - integrating into the XM. You can pull out the antenna from the XM module which is on the interior of a steel panel on the right side of the trunk. That gets rid of the preview, but an interference kind of noise, similar to beeping, still bleeds through. If you pull the main cable out, the XM function isn't useable. So that doesn't seem to be an option. I wonder if one (or more) of the wires in the cluster that plugs into the unit is for the audio transmission and could simply be cut, eliminating the audio but retaining the power so the unit (DROM, DomNav2go, etc.) would still work. Any ideas? I'm going to search for a schematic with keying for the wiring cluster that plugs into the XM module then give it a try. I'll post here when I do it.
Puma Jim
20
Oct 20, 2016 11:59 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
rockyboy
Sep 29, 2015 12:05 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
prbori
Sep 27, 2015 01:37 AM
