XM Preview Shut off - DomNav2Go
So I installed the DomNav2go system to my iphone. Everything works well but the xm preview bleeds through when I play videos. Does anyone know how to get rid of it?
I'd like to know this as well. I have the DROM Audio unit which works in the same way - integrating into the XM. You can pull out the antenna from the XM module which is on the interior of a steel panel on the right side of the trunk. That gets rid of the preview, but an interference kind of noise, similar to beeping, still bleeds through. If you pull the main cable out, the XM function isn't useable. So that doesn't seem to be an option. I wonder if one (or more) of the wires in the cluster that plugs into the unit is for the audio transmission and could simply be cut, eliminating the audio but retaining the power so the unit (DROM, DomNav2go, etc.) would still work. Any ideas? I'm going to search for a schematic with keying for the wiring cluster that plugs into the XM module then give it a try. I'll post here when I do it.
Puma Jim
20
Oct 20, 2016 11:59 AM
