where to tap wires for +12v, IGN, Illuination, and ground
B A N N E D
Hi, I am going to be installing some aftermarket components which require the following wires:
1. constant positive 12v
2. Ignition
3. Illumination
4. Ground
Where would the best / easiest place to get these wires? In the back of the radio?
2. Ignition
3. Illumination
4. Ground
Where are you installing your aftermarket parts?
1. Fuse slot #32 of driver's side fuse box with an "add-a-circuit" from AutoZone OR tap into one of the cig adaptors.
4. Factory ground bolt behind the liner in the trunk.
` . ' . SUV haterrr
Back of the radio is a good spot, and this was what I used. However, it makes sense if your project includes removing the radio, because removal is difficult
B A N N E D
Does anybody have the the colorcode of the wires that I would need in the back of the radio? Especailly the IGN and ILL wire.
Any help is appreciated!
Probably the middle connector on the back of the radio with 20pins. The book lists the following:
Yellow/Green-Radio switched power
Yellow/red-ACC (main stereo power supply)
Green/Red-Radio remote switch
Red/Black-Lights-on signal
White-Constant power
Acura604
20
08-05-2017 12:55 AM
soupi
14
11-15-2015 11:15 AM
SUPRMN84
10-07-2015 09:46 PM
