Where do I run my sub wire?
Old Aug 23, 2013 | 06:24 AM
reaper101's Avatar
live fast or die slow
I know where it is on the 2nd gen but where is it on the third tks
Also what's the alternator output on the 2nd gen and 3rd gen Ty guys and gals
Old Aug 23, 2013 | 09:25 AM
Jthewiseman's Avatar
Are you asking where to run the wires in a 3rd gen tl?...just trying to clarify the question
Old Aug 23, 2013 | 10:53 AM
reaper101's Avatar
Yes sorry I wasn't specific
Old Aug 31, 2013 | 05:09 PM
You can always do a search but for mine I ran it underneath the back seat then underneath the plastic pieces on the floorboard/where the door closes up to the driver area. Then try to feel around up to the left of the brake pedal and you should find a rubber grommet which runs into the engine compartment. I ran a 0 gauge wire through that hole with a little cutting of the grommet. Once you get it through the hole just run the wire in the engine department however you want to the battery
Old Aug 31, 2013 | 05:11 PM
Not sure on the alternator output though
Old Sep 2, 2013 | 10:02 PM
RxWorld's Avatar
Just is what I did. Makes a real clean install
Old Sep 12, 2013 | 12:24 PM
reaper101's Avatar
I found that grommet but couldn't find the wire in the engine bay, so I used the grommet in the driver floor board.. Still looks clean
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
VA2000TL
Oct 2, 2015 08:26 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
