When Keyless entrys headlight?
Old Mar 9, 2008 | 12:13 AM
goameri's Avatar
I vaguely remember the first time I unlocked my TL with the keyless entry remote, the headlight came on. I don't know if I press something wrong, but now when I unlock my door using the remote, my headlights no longer turn on. So, was I imaging thing or can someone tell me how I fix this problem?
Old Mar 9, 2008 | 12:29 AM
Gsilk's Avatar
9th Gear
It is an option under your driver settings on the info screen. You can choose different lengths for them to go off when you lock and come on when you unlock it. They will shut off after the 30 seconds (or whatever time you choose) if you do not open the door when unlocking the car....ie its bad to turn them off and on in a short period of time.
Old Mar 9, 2008 | 06:22 AM
BlueTypeSGuy's Avatar
Just leave your headlight to the ON position. Next time you press unlock, it will light up. It has an auto-off option in case you leave it on after X amount of seconds, depending on what you set it to.
Old Mar 9, 2008 | 06:13 PM
Acura 2c's Avatar
How do i change the settings on the auto-shut off option?
Old Mar 9, 2008 | 08:20 PM
MWalsh9152's Avatar
all work and no play
in my 06 I always left the headlights on, sometimes they would come on when I unlocked it, and soemtimes they wouldnt open untill I opened the door
Old Mar 10, 2008 | 09:58 AM
djbonsu's Avatar
"Like None Other"
^^^^....what makes the lights come on is if you leave the lights on as ppl have already discussed. however, if you unlock your door and and the lights come on, the timer activates as soon as the key fob is pressed. therefore depending on what you have your timer set to, then the lights will shut off if the car is not started or if the door is not opened after the vehicle is unlocked. hence, the lights may not come on the 2ND tme you hit the unlock but becasue the headlights timer has already timed out....so, as you can see, the timer would reset itself when you open the door
MrHeeltoe
20
Feb 23, 2023 01:54 PM
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
