Weak signal from the factory amp - no volume
I saw a few people losing power to their stock system and basically losing volume. Sound in my car slowly became weak over the past few months. Navigation, radio, etc all worked but it was literally as lound as my alarm clock.
Dealer suggested to pull it out, send it to california for $350 for an inspection, and not gurantee it would fix the problem....
no thanks. I removed the two pass kick panels, two screws holding the amp and two plugs on the amp out. I found a used OEM amp on Ebay for $60 shipped assuming this has to be the problem. Plugged it back in, scewed in the screws, popped on the panels and it solved everything
just a burnt up stock amp. Back to the clean factory stock look just the way i like it.
no thanks. I removed the two pass kick panels, two screws holding the amp and two plugs on the amp out. I found a used OEM amp on Ebay for $60 shipped assuming this has to be the problem. Plugged it back in, scewed in the screws, popped on the panels and it solved everything Last edited by ejgold55; Mar 6, 2012 at 01:41 AM.
4drviper
Apr 23, 2025 07:13 PM
navtool.com
31
Nov 16, 2015 08:30 PM
InFaMouSLink
Oct 30, 2015 09:43 AM
