Viper 5901 Window Module
Old 02-23-2010 | 01:33 PM
carfreak55's Avatar
Carfreak
hey guys i'm planning to install the VIPER 5901 on my 05 TL. but i want to install it with the window module so... when i press a function button all 4 windows open including the sunroof and when i press it again I want it all to roll up.
1.Does anyone know which window module i should get?
2.Which one is good with the viper 5901?
3.is it all universal?
4.Should I get 2 of 2 window roll up or one of 4 window roll up.
please advise..
thx in advance
-Henry
Old 02-23-2010 | 02:52 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
You can use either the DEI 529 or DEI 530T depending on how much control you want. The DEI 529 module will control either one window up and down or 2 windows in either one direction only up or down. The 530T will control 2 windows up and down or 4 windows in one direction, up or down.
Make sense?
If you want to just be able to close all ur windows on lock, you don't need any of these modules as you can tap into the factory wiring and simulate your key being in the key hole.
If you want to control all windows and up and down from the remote then you need 2 530T modules.
Old 02-23-2010 | 03:07 PM
Trew's Avatar
^ nerd
Old 02-23-2010 | 03:09 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
Old 02-23-2010 | 03:16 PM
carfreak55's Avatar
Carfreak
Make sense?
thx for ur help Elegant!
le^2
05-30-2018 10:50 AM
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
xsilverhawkx
10-05-2015 11:00 AM
xsilverhawkx
09-28-2015 06:51 PM
AcuraKidd
09-25-2015 11:18 PM
Quick Reply: Viper 5901 Window Module
