Viper 5900 problem - its driving me nuts!
NPB TL FTW
So ill make this short
- got the viper 5900 installed
- go to start my car or unlock doors, and the acura alarm would randomly go off
- only way to stop alarm is with the acura remote and not the viper remote
has this ever happend to you?
i hope my installer will take a look and fix this for free
Let's Go Pens
Did you use the right bypass module to override the factory system? I have the V91XV on my Envoy and had a simlar problem until I realized it was a defective module. Just something you might want to look into
Stacking chips.
That happens very randomly on my 5900sst. But i have the stock remote on my chain too, because the viper remote doesn't do driver memory when you unlock it.
NPB TL FTW
i got the solution from the guy
I rather he do it for free but he wants to charge me 50$
There is a Black Red or white wire on a module inside the driver door to disarm the Acura alarm without unlocking the door.
To do so we need to dismantle the door to access the module and tap on the Wright wire and pass one wire from the inside of the door all the way to the under dash and hocking up to the alarm.
So when you will send a command for remote starting to your car the Viper will send a 1/2 second pulse to the module in your door and disarm the Acura alarm.
I can attempt to do it if you want to.
50.00$ tell me when you are free to let me your car.
I am surprise that it do not go off every time you send a command at your Viper.
cycdaniel
12-17-2019 10:58 AM
nanos
11-12-2015 08:41 PM
brandnewcolony
09-12-2015 10:39 AM
HeloDown
09-08-2015 06:51 PM
