vibrater trunk
Old Sep 9, 2010 | 03:53 PM
mrconnecticut's Avatar
2004 Acura TL
vibrater trunk
so i put a system in my car and the trunk vibrates like crazy!!! how do i stop this?
Old Sep 9, 2010 | 04:10 PM
swoosh's Avatar
takin care of Business in
take it out
turn the bass down
ok well....did u use dynamat ? try using all 4 bolts on the rear license plates....
Old Sep 9, 2010 | 04:38 PM
2004 Acura TL
i have all 4 bolts.. it isn't just the plate that's vibrating.. the whole trunk/rear window looks like it's gonna pop out from all the bass lol lol
Old Sep 9, 2010 | 04:43 PM
swoosh's Avatar
did u dynamat the full trunk before the install ?
Old Sep 9, 2010 | 07:43 PM
crzygosu87's Avatar
Down for a photoshoot?
Specs on your system?
Also just an option ... but maybe you should take one of swoosh's initial advice and turn down the bass/volume hahhaha
Old Sep 9, 2010 | 07:50 PM
eduardmc's Avatar
Acura TL 04, G37s 19"
i was about to post this, i did dynamat my trunk and still rattle like is going to brake. i had a type r on a cheap box but today i switch to a custom box tune to 30hz, giving it 600rms. Any doubs i had that my system was not good enough was gone. Now is more than enough i love the clean clean bass but the trunk now rather way to hard even with dynamat. what can we do to fix the trunk rattle.
Old Sep 9, 2010 | 09:37 PM
TLingham's Avatar
First see if your girlfriend likes it.
Old Sep 9, 2010 | 09:43 PM
I hate cars's Avatar
Search.
Old Sep 9, 2010 | 09:48 PM
swoosh's Avatar
do you have a wing spoiler or a trunk lip ? i know the trunk spoiler has a knack of rattling....
also the rear aspec will rattle too....plus the spare tire + accessories will rattle.....try taking everything out of ur trunk and then try it....
Old Sep 10, 2010 | 04:15 AM
PowerCommander's Avatar
Several things I'm sure is happening. One the back dashboard cover (where your oem sub was located) is likely vibrating and hitting your back window and or other things. Dynamat that entire area and make sure it's secured. Find insulators if you have to to keep it from vibrating so it is firm when it's latched. Try to find areas where it might be vibrating againts another surface causing it to make more noise than it should. The other would be that plastic piece where your license plate mounts to. Find a way to keep it from rattling againts the metal surface of your truck cover. Then if you haven't done it yet make sure to dynamat as much of your interior surface as much as possible. Another thing to is to place a dynamat piece to the whole entire back surface of your license plate before mounting it on. If you don't have dynamat in hand, use the heavy duty (ussualy red) double side tape from home depot or hardware store as a temporary fix to keep your license plate from rattling. You might have a good system and it might sound good inside but it's really annoying and sounds super cheap if your shit rattles so much from the outside.
Old Sep 10, 2010 | 04:47 AM
VQPower37's Avatar
Old Sep 10, 2010 | 08:08 AM
eduardmc's Avatar
my trunk rattles to much i'm going to dynamat it more this afternoon, but i see the rattle is coming more from the license plate and platic cover in the trunk. now it hits much harder with my new box since is hitting those lower hz even harder.
Old Sep 10, 2010 | 08:15 AM
Glad to see the new box worked out for you.
Now, I know a way to stop the rattles. This is for the OP and eduardo....
Build a a mini dream box ( bandpass) that ports into the arm rest of the back seat.
not only will you get amazing bass, but it will stop all rattles as it sits over the axles and not in the trunk itself. Plus all the sound is ported into the cabin.
Old Sep 10, 2010 | 09:29 AM
eduardmc's Avatar
thanx for you advice about geting a custom box, i used audio classified now i have a custom ported box tuned 30hz for the type r, it fits perfect and it sound 10x better, i already had what amp and sub i was about to get but now the type R sound so clean and so loud which is more than enough. i heard a custom banpass for 2 kicker and was no trunk rattle what so ever. Now i'm afraid of going bandpass and loosing my ported clean SPL SQ sound.
any thought on this?
Old Sep 10, 2010 | 09:38 AM
ported boxes = SPL
Sealed boxes = SQ
what do you get when you put them together?
Bandpass = SPL and SQ.
Here is more info and build threads on the bandpass box made for the TL.
I'm currently buidling a mini dream box. well, my sub is a little bigger than Triodesigns but smaller than CSW's. it will be a "medium Dream box"
Old Sep 10, 2010 | 12:37 PM
2004 Acura TL
nothin to crazy but it does rattle EVERYTHING
Old Sep 10, 2010 | 03:13 PM
RBeachTL's Avatar
One of the most significant causes of rattles is the hard plastic of the rear deck lid vibrating against the rear deck metal. I used felt where ever the hard plastic contacted the metal deck. This was very effective.
Old Sep 10, 2010 | 04:43 PM
1995hoo's Avatar
Keep Right Except to Pass
"New box" in a "vibrator" thread.....
Old Sep 14, 2010 | 07:14 AM
MeThane's Avatar
I have two 12' alpine type R's in my trunk and when I first had it in these were the rattling problems that I found .
1. As "PowerCommander" mentioned the Backdash was vibrating and hitting the back windshield . I have yet to actually go back there and find a solution . But i just threw my book back behind one of the back headrests and that has worked for me as a Temporary solution as of now.
2. I had a Trunk deck lid , took off . HELPED A LOT !
3. Now , I took out the liner of the trunk (only on the part that goes up) Took out the dead weight that holds the trunk down . So now when I pop my trunk it Goes straight up and you can see my subs when I try to show off . But , One thing that I noticed that rattles in my car is the licenses plate lights . In that area there are a couple of plastic peices that shake like a mother once I have my subbs turned up .
4. As mentioned above , I added all four screws to my license plate. And removed the ' Karen radly cover from the dealership ' Cover.l
Old Sep 17, 2010 | 05:31 AM
babythug's Avatar
I have an 05 TL A-Spec, and i put 2 12' MTX jackhammer subs in, my trunk was doing the same thing.
all i did was line the whole car with Fatmat, and adjusted the trunk latch, now it sounds great.
oh and i know you guys are going to ask what Fatmat is, well fatmat is like dynamat but 10 times better and 100 times cheaper.
if anyone wants to see pics let me know
Old Sep 17, 2010 | 07:47 AM
eduardmc's Avatar
well i got rid of the license plate vibration and ithink i found the solution to getting rid of alot of trunk vibration. This will not stop it but minimize it.
Go to lowes and get "peel and seal" is very cheap. $15 for a 9" x 25 ft. on the trunk remove the liner and cover and sealed the entire upper trunk. the license plate vibration is coming from the bass hitting behind the license plate holder.
Try to put many layers of peel and seel and your trunk rattle will "almost" gone i get no more license plate vibration anymore.
Old Sep 17, 2010 | 08:13 AM
MeThane's Avatar
I would like to see pics
Old Sep 17, 2010 | 12:12 PM
babythug's Avatar
Do you want to see pics of the fatmat in the trunk or the car all together???
Old Sep 17, 2010 | 01:58 PM
dwb993's Avatar
More info on this, please? How do I get to it and remove it?
Old Sep 17, 2010 | 02:00 PM
There's a weight on the underside of the trunklid. If you remove the carpet you will see it. Remove two bolts and it's out.
Old Sep 17, 2010 | 08:29 PM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
i wanna see pictures of the whole trunk.
We here on AZ never heard of FATMAT before. must be canadian...
Old Sep 18, 2010 | 07:13 PM
babythug's Avatar
no its not Canadian. i got it from the US.
Old Sep 19, 2010 | 10:38 AM
dwb993's Avatar
Thanks again, IHC. Got it out yesterday!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
baelim
May 10, 2018 09:53 AM
joflewbyu2
Oct 8, 2015 11:16 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
