v710 blue tooth ?
Old Jan 3, 2005 | 07:38 PM
rescueswimmer's Avatar
v710 blue tooth ?
I have a ? about the blue tooth setup on the v710. Here is my question I have my phone setup so that when I get in the car and plug it in and turn on the car it automatically recognizes the phone. When I shut off the car and check the phone the bluetooth connection is off. My question is the battery wearing down faster this way. Or once the bluetooth is off that phone is not searching anymore. Thanks for the help
Old Jan 3, 2005 | 07:42 PM
vp911's Avatar
If I am not mistaken it is always searching... there was one moto...the v551 (for att/cing) that stopped searching...
Old Jan 3, 2005 | 07:50 PM
NFLblitze1's Avatar
Youse Gots Sacked
plugging it in? the whole point in bluetooth is so its wireless.....
Old Jan 3, 2005 | 08:04 PM
vp911's Avatar
plugging it in for the power... bt eats up battery quickly.. im pretty sure thats what he meant
Old Jan 3, 2005 | 09:47 PM
VC Slim's Avatar
BT is quite a drain on my V551 so set a phone shortcut to turn the BT power on and off. Once turned on it will auto connect to the HFL.
Old Jan 3, 2005 | 10:19 PM
Hawhyen51's Avatar
Here's a post I copied for shortcuts to turn bluetooth off and on, I forgot which post I took it from. Yes, BT does drain the battery faster and best to keep it plugged in with car power adapter.
Actually, you can make it even better than that (thanks for the head start, though):
1. Menu
2. 7 - Setup
3. * - Connection
4. 1 - Bluetooth Link
5. Setup (Select)
6. Power (Change)
7. Scroll down to "Off"
8. Hold then Menu button down and create a shortcut...I used "1"
Follow the same steps as above (1 through 6) and then:
7. Scroll down to "On"
8 Hold the Menu button down and create a shortcut...I used "2"
Henceforth, "OK" + 1 turns Bluetooth off in a single step
"OK" + 2 turns Bluetooth on in a single step
Jul 16, 2017 07:33 AM
bluetl04
Aug 16, 2016 02:49 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
dirleton
Sep 29, 2015 08:26 AM
thegipper
Sep 28, 2015 01:01 PM
