V1 to overhead console
Old Mar 30, 2005 | 07:36 AM
jeffpeer's Avatar
Question V1 to overhead console
How do I remove the overhead light/sunroof control panel to hardwire V1 there? Also, how do I identify the power lead to the sunroof (or another 'switched' source). Thanks, Jeff
Old Mar 30, 2005 | 10:00 AM
rbf351's Avatar
Registered User
very simple to remove, the put your fingernail under the sunroof switch and it basically falls out, then just grab from inside the switch hole and pull, the entire thing just falls out, i forget which wire is which up there, but use a test light from the wires that goto the dome light if you are looking for constant power or use the sunroof wires if you are looking for switched power
Old Mar 30, 2005 | 01:20 PM
jeffpeer's Avatar
Thanks for the quick response. I'm new to the forum. Picked up my TL yesterday.
Old Mar 30, 2005 | 03:14 PM
vp911's Avatar
welcome to the forums. congrats on the car. check the 3g garage for V1 installations. i suggest NOT tapping into wires. get a "add a circuit" unit from a local auto place (like autozone) and connect directly to the fusebox. that way - if you have any electrical problems with the car the dealer cant blame your v1. besides is a cleaner install.
mlody
Dec 4, 2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
MikeJM310
Sep 24, 2015 07:24 PM
