V1 Mute button
V1 Mute button
Has anyone discovered a way for a remote mute for a V1? I do not want to move the Arrows by using a the concealed display. Or allow both sets of arrows to light up on both the unit & concealed display?
-Greg
-Greg
I'm confused by your post.
If you want a remote mute, then you need the remote display, which has a remote mute button on it. If you plug in the remote display the display of the main unit it turned off, and only the remote display works (this is good so you don't advertise to cops 1/2 mile behind you, that you have a detector on your window).
not vtech... VTEC!!!
Read these 2 articles from Audiworld...
http://www.audiworld.com/tech/elec80.shtml
http://www.audiworld.com/tech/elec69.shtml
A friend on Audiworld made a batch of remote mute for us using the article.
It work in conjunction with the remote display - it's a little contact switch that plugs into a regular telephone duplexer which shares the port with the remote display.
I used silicone and glue that switch to the back of the light switch stalk.
321 whp SAE
Velentine sells the remote mute. https://store.valentine1.com/store/ look at the bottom unit
Originally Posted by Aznpersuasion
Do you know anywhere that still sells the V1? ~Jason
http://www.valentine1.com/
soupi
14
11-15-2015 11:15 AM
