V1 concealed Display on TL?
Does anyone use a V1 with the concealed power display? Was curious if it would fit in the power outlet, I know the power outlet is re-cessed a bit and the lip of the concealed power plug might not make it in.
Anyone know?
Kevin
Anyone know?
Kevin
Shift_faster
Anyone know?
Kevin
Anyone know?
Kevin
I still havent figured out a good solution to where to hardwire the concealed display. I believe some people have some intricate systems set up though. Can't find the threads right now...sorry.
I found a very awesome product for BMWs, wish they had it for TL
http://www.jaricdesign.com/products.htm
I just posted in the forum asking them to develop that product for the TL. Everyone interested should go post in their forum under my post.
FYI, the product should display the ValentineOne info. on the navi. display or in the MID if they can make it do what it does in the BMW's.
Ok I just emailed the compny to see if they would be willing to make this for the TL we will seee what kind of response we get from them. If we need to put together a Group BUY I am sure there are people who would be into this plus would have to get a much better price cause $200 is to much I think
![Fluffy](https://acurazine.com/forums/images/smilies/fluffy.gif)
![Uzi](https://acurazine.com/forums/images/smilies/uzi.gif)
My V1 remote display is hardwired in the bottom cubbie, next to the power outlet, secured to the underside of the pivoting door. The wire goes through a hole in the back wall of the cubbie. When I need to hide it I just push the door closed. And it looks cool when you open it and the display just appears.
V1 is in the upper left hand side of the window. It's invisible from the front or back and even when you lean in from the outside you can't see it. I've had V1's mounted there for 10 years and have had great success avoiding the flashing lights.
I don't think you need the remote display in your direct line of sight. When you get a weak signal you have more than enough time to glance down at the display ( at least I seem to ) to figure out from which direction the threat is coming. If its' throwing multiple threats I usually just let up on the gas then glance down at the remote display. I value the remote display for it's stealth: blacking out the main display to travelers from behind and for when I lock up my car other than my garage. My V1 is hardwire but when I leave the car I don't have to remove anything yet you can't even tell it's there.
![Rock On](https://acurazine.com/forums/images/smilies/rockon.gif)
TLover
1 Post
can u take a pic. i cant seem to understand where exactly did u put it.
Anyone know?
Kevin
Anyone know?
Kevin
My V1 is not hardwired...I set it up for long highway trips only.
I experimented with the concealed display in the power adapter area, but I also found that not having it in my line of vision was annoying. So now I have attached a small piece of velcro just behind my steering wheel. When I set up the V1, the concealed display gets velcro'd there, and the unit itself goes on the passenger-side visor. It is powered from the power adapter in the dashboard...the one that cen be hidden behind the closing door, behind the gear shifter.
I run the cable from the V1 unit behind the rearview mirror, so the cable is not that annoying. The other cable runs up to the concealed display, but of course connects on the wrong side of the display, which is annoying. I actually wrote to V1, to see if they would make a concealed display with the jack on the other side, since that would work better for me, (and I expect hundreds of other people) but it doesn't seem likely.
Anyway, that is my solution, cludgy as it may be.
Andy W.
I beat you to that one, they responding back with a lengthy email that consisted of the word "No" and that was about it
ITSJESTER
17
12-06-2018 02:29 AM
