USA Spec PA15-HON3 not being recognized...
Fearless DIY Guy
Is there something more to just PnP for this device? I removed the working PAC unit for this one, and BOOM, nada
Something with the dip switch settings? This SHOULD just be PnP, right?
What mode do you want your idevice to be in?
For your Aux input to be usable, set Dip #1 to ON.
For Folder Mode (XM Only), set Dip #2 OFF, Dip #3 ON, Dip 4 OFF.
For Playlist Mode (XM Only), set Dip #2 OFF, Dip #3 ON, Dip 4 ON.
For Direct Mode, set Dip #2 ON, Dip #3 ON, Dip 4 ON.
How do you have your set up?
DeathMetal (10-11-2011)
I have one small thing I would like to change if possible though. How do the different switches effect the controls?
I am pretty sure we put it in direct mode. I can change tracks using the tuning dial, but only have like 6 songs available if I use the steering wheel to skip tracks. Can this be changed by switching the dip switches?
No go for me
So, you were able to get yours to work? I cannot get mine to be recognized by my radio. I press the XM button and get nothing. Does charge the iphone though. Weird.
No workie
Tried all the various DIP switch configurations, ohmed out the harness, and double-checked the plugs and it still does not work. I think module itself is NG. Working with tech support to resolve the issue, but I bet I will have to return it back to the folks I bought this from (Off Amazon.com). We shall see...
The XM button is completely non-op and when I plug in to my iPhone(4S), all is see is "Accessory detected". No good....
emailnatec
29
09-28-2018 04:27 PM
4drviper
09-23-2015 07:42 PM
