New IB sub
Old Jun 6, 2012 | 01:51 PM
liljojo4711's Avatar
New IB sub
is there a direct replacement aftermarket sub that fits in the same spot the original is in? it is an 8" sub correct? any idea how much power the factory amp puts out to the sub?
Old Jun 6, 2012 | 02:42 PM
jda123's Avatar
Dogmatic Dinosaur
About 30 to 40 watts... maybe.
The stock sub is free-air, not IB, although it would likely work as IB.
If want a direct replacement with little additional work, then look for a free-air sub.
There are some threads on here about some subs that mostly drop it.
Old Jun 6, 2012 | 02:44 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Every question you asked has been asked about 10000000000000000000000000000000000000000000000000 000000000000000 times here. Try to search first and see if you can find your answer, especially when it's that general and likely already known or covered. The "SEARCH" function is right in the middle of the page at the top of this forum.
I know many people have replaced the 8" sub with something else, but you're just polishing a turd. A flimsy metal sheet isn't the best mounting location for a sub (if you can even call this that). The factory amp gives the sub roughly 55 watts if I remember correctly, but no telling how clean that really is. Also, you have EQ going on in the amp and your x-over is already set so you're stuck with those unless you tap the signal BEFORE the factory amp, which is located in the passenger kick panel.
You have plenty of other options for space saving (seems like that's what you're going for here). You'll see them when you begin to search and pull up people that went a different route when asking the same question you have
Old Jun 6, 2012 | 11:20 PM
stevemk07's Avatar
I think the subject needs revisiting. In all my searching the forums for a drop in replacement that works well I found many people struggling with the rattling of the rear deck. I did not find anyone that had tried the drop in replacement to uncover the fact that most of the rattling was coming from the cover on the deck hitting the rear glass.
I am very happy with my .54 cubic feet sealed 10" enclosure in the trunk (fits nice and snug in the corner) but I do not think may subs would work this well in such a small enclosure (hitting it with about 450 watts).
Part of me wants to try cutting a couple of wood blocks to fit snug inside the deck to strengthen in, deaden surrounding area some more, and then fit a suitable 8" sub in there powered by about 100 -200 watts.
My recommendation would be to amp the sub separately unless not looking for a substantial improvement as most of the aftermarket subs are probably less efficient than the stock sub. My 10" Hertz hi energy sub is very efficient at 96 dB but they don't make these ones anymore. If you found a very efficient aftermarket sub I would try dropping it in, placing something in between the rear deck and glass and see how it does, then go from there.
Btw, some people are very good at polishing turds!
Old Jun 7, 2012 | 12:56 AM
pohljm's Avatar
Acura did not make the rear seat fold down for one reason! IB
Old Jun 7, 2012 | 02:05 AM
I hate cars's Avatar
Which sub are you running? The hi energy 10" I've found are 86db efficient 1w 1m. They have a misleading excursion rating using peak to peak instead of one way.
Drop in subs have been tried over the years, none with success. One person did an elaborate setup attempting to seal the deck with no success. The thing is, no 8" sub with enough throw for any sort of respectable output will be way too deep to fit in the deck. Any sort of respectable output will rattle the hell out of the sheet metal. To do it properly the front wave still must be sealed from tbe rear wave so you must seal behind the seats and any holes on the deck. It would hardly be any additional trouble to do a pair of 15s IB.
On a lighter note, they've started making the original IB15 again at $199 or even less if you buy 4 or more. I'm stocking up. Anyone want to go in halves to get the 4 or more discount?
Old Jun 7, 2012 | 07:32 PM
pohljm's Avatar
I might be interested in funding at least a single IB15! but I am not gonna re do the baffle thats only a month old for duals.
Old Jun 7, 2012 | 08:09 PM
That sounds good. I'm doing 4 of them no matter what but I figured I would share the discount if anyone else was interested. Looks like $175 is the price for the 15" if you order 4 or more. That's incredibly cheap for what you're getting. I won't be ready to order for a month or so but I'll PM anyone who is interested when the time comes.
Old Jun 7, 2012 | 09:41 PM
stevemk07's Avatar
"They dont make them anymore." 96 dB
I read all that too.
Old Jun 7, 2012 | 09:43 PM
thanks for the replies. i searched this before i asked the question and like what was stated above, there was never a clear cut answer besides buy a new sub and amp and mount it in the trunk. if there isnt any decent way to do it, ill get a sub and amp like i have done in every other car i owned. thanks for the replies.
Old Jun 7, 2012 | 11:32 PM
pohljm's Avatar
Matt, I am in no real hurry, just enjoying my $58 special. But I bet by the time your ready I will be feeling the itch for a lil change. I will commit for a single
Old Jun 8, 2012 | 12:44 AM
tegman2's Avatar
Maybe me. You still going to make it to the Kansas meet?
Old Jun 8, 2012 | 12:52 AM
I'm going to try but I have the IRS literally attempting to steal everything I've ever worked for right now so it's wholly dependent on what happens with those thieves. I would really like to go. If I do, you're more than welcome to have a listen.
Old Jun 8, 2012 | 07:50 AM
Kansas meet? Where at in KS? I could swing that possibly
Old Jun 8, 2012 | 10:05 AM
tegman2's Avatar
https://acurazine.com/forums/midwest-312/2012-national-acurazine-meet-june-9-10-kansas-city-new-info-posted-may-30-p-18-a-850113/
This weekend. KC
Old Jun 8, 2012 | 11:42 AM
Hm. About a 5 1/2 hour drive for me. Why can't it be in Wichita lol.
Old Jun 8, 2012 | 07:18 PM
wilztlxs's Avatar
TLX-S
I recently installed the following 8" Pioneer sub in place of the stock sub, re-wired the sub wires to RCAs to a Pioneer amp and it easily sounds 10x better than the stock sub. I got rid of the majority of the rattles in the rear deck and don't hear any rattles 90% of the time unless I turn it up too high.
I wasn't looking to be bumping anything high all the time, just wanted something that sounded better cause the stock sub wasn't cutting it.
http://www.pioneerelectronics.com/PU...ount/TS-SW841D
I got the sub and amp for around $160
Old Jun 8, 2012 | 10:14 PM
eggyhustles's Avatar
that pioneer needs a port
....baddddddddddddddd
god..the motor on my midbass is bigger.
Old Jun 9, 2012 | 01:28 AM
stevemk07's Avatar
Is that an inferiority complex I see? Seriously, whenever someone is satisfied with their system you chime in to tell them why you think it needs to be improved. Who taught you that?
Old Jun 9, 2012 | 11:25 AM
Yes master
you have me figured out.
Old Jun 9, 2012 | 12:28 PM
Yes master
Lol. Its not about the magnet size, its the way you use it. But yeah, a short throw 8" is just not going to cut it for most without being ported. I hooked my stock sub to my home system just to see what kind of excursion it has and its only around 5/8" peak to peak before bottoming.
Old Jun 9, 2012 | 01:15 PM
wilztlxs's Avatar
TLX-S
i had two Alpine 12's in a ported box with a JBL amp in my old RSX-S. i wasn't looking to go that extreme with the TL and wanted to look stock. i'm happy with how the Pioneer sounds over stock and got the amp/sub for a good price.
Old Jun 9, 2012 | 03:05 PM
stevemk07's Avatar
Yes master
I apologize for that comment. Was in a pretty sour mood last night.
Old Jun 9, 2012 | 03:09 PM
It's all good.
I never take it personal.
Old Jun 9, 2012 | 04:34 PM
It's all good.
You suck Eggy! I'm going to give Biggs a call and get him back over here.
Old Jun 9, 2012 | 04:42 PM
Old Jun 9, 2012 | 05:45 PM
me and him are cool, now.
he even showed me the JL mural tat on his back.
Old Jun 9, 2012 | 06:12 PM
Lol.
I know you have a Sundown tat somewhere.
