USA SPEC PA15-ACU XL Installation for Acura TL 2007
I installed a USA Spec PA15-ACU XL iPod module for a '07 TL. Since there isn't a specific thread about installation of this module for an '07 TL, I thought I'd share. Hope it helps someone.
I read a few other threads before attempting my own installation. They are referenced in the "Reference" section.
PDF
Admin: If you can host the .pdf file somewhere permanent, it would be great.
Sj Espo (05-22-2012)
Hey man,
Trying to do this install myself - but the pdf isn't working for me... Could you reload or at least post some pics of the xm nav location in the trunk and how to get to it?
Thanks!
Thanks!
1. Remove trunk liner (see picture at end of post) to expose the right rear of the car as pictured below. Remove the door edge plastic trims. You can remove as many pieces as you need/want. I removed all of them all the way to the front passenger area.
2. Loosen the three bolts (orange stars) that secure the XM module (don't completely unscrew the bolts). Slide the bolts toward the larger holes and remove the XM module from behind the metal sheet.
Take a look at this thread for additional pictures.
3. Connect the PA15-ACU XL wiring harness as detailed in the manual included with the unit. Re-install the XM module.
4. Thread the harness cord through the opening where all the existing wires pass through to the right back seat. Secure the harness cord neatly with plastic ties and trim the excess.
5. Run the hardness cord to the right of the front passenger seat. Pass the cord underneath the seat to the middle (or wherever you want to position your PA15-ACU XL unit). Secure the cord with ties and trim off excess. I also used a Fostner bit to drill a hole where the cord exits the piece of plastic trim to relieve pressure on the cord once the plastic trim is re-installed.
6. In order to store the iPod in the center console armrest, you need to run the iPod cable underneath the armrest to where you position your PA15-ACU XL. Open your armrest console and remove the rubber mat at the bottom. Then remove the plastic cover underneath the rubber mat to expose the underside as pictured in this thread.
7. Remove the two screws at the bottom of the now exposed center console compartment. Once they are removed, you can gently lift the center console and run the iPod cable to the PA15-ACU XL as pictured below. Use industrial strength Velcro (Lowe's store) to secure the PA15-ACU XL unit to the carpet.
![](http://img214.imageshack.us/img214/5920/dsc27302.jpg)
7. Use a 1/4" Fostner bit to drill a hole at the corner of the plastic cover and the rubber mat where the iPod cord will pass through and into the armrest console. For the rubber mat, made a cut from the drilled hole to the edge so that the iPod cord can be neatly passed-through (pictured). Can you find a mistake I made?
![](http://img829.imageshack.us/img829/5243/triplet2.jpg)
8. Hook up your iPod and test it. Put all plastic trims back where they came from. Returned trunk liner to its original place.
![](http://img829.imageshack.us/img829/769/71232243.jpg)
By the way, I suggest running to Harbor Freight and buy you one of these to make removing the plastic trims, etc. much easier. They are called "Auto Trim and Molding Tool Set."
![](http://img837.imageshack.us/img837/5899/dsc2731.jpg)
![](http://img687.imageshack.us/img687/9595/dsc2733p.jpg)
![](http://img517.imageshack.us/img517/356/dsc2720d.jpg)
The following 3 users liked this post by T0L8:
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
PDF
Thanks for the pics and instructions, got it installed but went the easy route and kept everything in the trunk because I don't really need to access the ipod. Or so I thought... I've been having problems with the nav unit just going back to xm sat randomly and each time I have to unplug and then plug in the ipod to get it to sync/work again. Any suggestions?
silvrbreez (01-30-2013)
mdrosenkrans, I don't have your problem. I had one instance where I can't change PL, but disconnect/reconnect the iPOD solved it. I concludes that this iPOD adapter still has bug. So far, I haven't regret buying it.
PDF
Any other "bugs" I should know about before I install in the next few days??
Any glitches with factory navigation or stereo?????
Well I'm having issues with XM radio playback. When changing stations sometimes theres a mute like its going to change stations and then nothing, remains on same station. Other times the music changes but the ch. # stays the same. Other times it also changes the ch. # changes but the music stays the same. It also from time to time says on the LCD display above Navi screen that XM is loading....big time lag issue here, had Acura dealer install it but they installed it under center arm rest console now I don't have access to the USA SPEC PA15 ACUxl unit, may it be a dip switch issue or is this something I'm just gonna have to live with????? HELP!! It's annoying wanting to change channels but don't now really for fear of lag issue, just listen to whatever is currently on whatever XM station I'm listening to, sucks because I'm a channel surfer!!
Can this method work with the 2005 TL? I'm having a hard time installing the (USA-Spec PA15-HON3) thru the front console. So i might try doing it from the trunk instead if that's possible.
USA spec causes xm to lag
I'm having the same lag issues with using XM in my '07 TL. The iPod functionally appears to work normal, but when trying to use XM the controls are very sluggish or sometimes non-responsive. Has anyone experienced this and been able to diagnose the problem?
If I install this USA spec device am I correct in assuming that I can only have either XM text or ipod text but not both? So If i retain the XM text then wouldnt that defeat the purpose of the device becuause I wont know what im scrolling thru?
not sure if that made sense.
thanks
thanks
Trunk Removal
Do you have to remove all of the pieces in the trunk to get to the XM moduler?
What is the bare minimum I can remove to get acess to the XM module?
Thanks,
Jeff
Thanks,
Jeff
Where could you put this in the trunk if you don't want to run the wires through the car?
I really don't need access to the ipod and want to leave it in the trunk. Just don't know where/how to do that?
I'm sure some of you have already seen this step-by-step install video, but I thought I'd post it for others to see. I'm gonna follow this video when I install the usa spec in my 07 TL.
Sorry guys, I posted the wrong youtube video before (shows only the USA Spec product). This video is the one I meant to post originally. It is a great, detailed walkthrough on an install for the USA-Spec PA15-ACUXL. I really like how they went down the molding alon the doors, and under the glove box to a ProClip mount.
LeMix (02-18-2013)
ReamzTL2
Power question
Does anyone knows how you power up the unit? I hope u don't have to connect it to the battery becuz it will drain the battery. I'm hoping that the harness to this unit brings a cable where u can give the power to juice it up. Need some guide on this
I have been looking everywhere for a video or pics showing the removal of the 3rd Gen's right side trunk liner to get to the XM module. This thread is the closest I've come, but the vids are dead. Anybody happen to be weird like me and save any of these vids to your hard drive? Or does anybody have a link or another tutorial? I saw the one on Youtube with the RL, but it's not nearly the same thing. I also saw these links (https://acurazine.com/forums/3g-tl-a...type-s-698771/ and https://www.handa-accessories.com/ac...cord-xm4dr.pdf ) but neither show the liner being removed. Thanks in advance.
nuldabz
09-03-2015 05:49 PM
