USA-Spec BT45ACU
USA-Spec BT45ACU
So I just picked one of these up, and I am pleased with how easily it installs as well as the quality of the sound; however, for those (if any) of you that have this, where did you mount this sucker? I was maybe thinking of using the aux one day, but the Y-cable isn't nearly long enough to run to the front of the car. Thinking of just keeping it mounted right by where the rear armrest opens to the trunk then I suppose back seaters could use the aux/usb charging ports. Any thoughts?
~t.s.
~t.s.
I have the BT45-HON3, and bought it specifically for BT so I wouldn't have to mess with drilling holes for the wires and such. If you want to opt for just BT, then what I did was shove the unit in the little slot between the metal bar and radio. The grouped up wire and the size of the unit was enough to hold it in place by itself. 3 weeks in and still no rattle
The XM receiver is in the trunk yes. Not sure why that matters though, because when I looked at the install instructions and everything online, everyone unplugged the back of the xm thing in the front, just under the radio. I'm not familiar with the RL, but I'd expect the install on it to be the same as any other kind of AUX unit in that section
~t.s.
acuragod
21
07-09-2013 02:50 PM
nightkidtypes
10-27-2011 06:11 PM
pprewett
35
01-02-2009 11:06 PM
