Upgrade of my Acura 2004 TL System, let's build it!
Old 01-30-2013, 03:04 PM
  #41
Gregerst's Avatar
I've got a RF-BLD if you want to go that route.
Old 01-30-2013, 03:41 PM
  #42
thedeadmanx's Avatar
Is that required though? The RF-BLD? Can I just tap in directly , splice to RCAs and put those into the sub amp and then over to the comp amp?
Old 01-30-2013, 04:04 PM
  #43
pohljm's Avatar
no line driver required to feed my JL amp
Old 01-30-2013, 08:12 PM
  #44
Gregerst's Avatar
Not required with JL and I ran an Alpine PDX amp without one and it was just fine. Most amps are rated down to 200mV inputs. It's just that some amps work better than others. The JL actually has a low / high input selector for this purpose. I'm running an RF-BLD with my curent PPI amps because the review I read said it liked higher voltage. Meaning the amps were low on the gain and would require turning them up. But having about 2000 watts of effient class d power for less than $400 was woth it for me to run a line driver plus the higher input voltage from the line driver means a cleaner signal. I have the gain completely turned down on 4 channel amp and at about 1/4 on the sub amp.
AndrewS
19
03-14-2024 06:59 PM
02-25-2020 09:57 AM
Soul_Deamon
11-13-2018 04:44 PM
ExcelerateRep
12-11-2015 12:58 PM
Zonian22
11-14-2015 01:20 PM
Quick Reply: Upgrade of my Acura 2004 TL System, let's build it!
