Underglow connecting to headlight sensor?
i dotn'w know if i'm asking in the right place...
but...
you know how when you press "unlock" on your key, the TL's headlight turns on for like...20sec?
i would like to mod my TL with underglow neons just for fun..and is there anyway to connect the circuit that, when i press unlock, the neon turns on also along with the headlight?
thanks
but...
thanks
2004 SSM/EB/5AT/Navi/RSB
The headlights would only come on at unlock if you left them on when you locked it.
Regarding the question, you'd need to just connect the neon to the headlight circuit, but I'm guessing you don't always want it on. In that case, you could add a switch for the neon in series with the wire from the headlight circuit so you can disable it.
cycdaniel
12-17-2019 10:58 AM
joflewbyu2
10-08-2015 11:16 AM
navtool.com
09-25-2015 05:15 PM
