Two questions, stereo and Navi
Both of these questions relate to my ex-wife's 05 TL with navigation. Firstly, the back lighting for the stereo is out. I can't determine a fuse for this. The stereo works just fine, just no lighting at night. Nothing else is out on the console. Can anyone direct me to a fuse or connection? Secondly, her navigation system has "gone bad" and is displaying only "PLEASE CHECK DISK." Is there a way to kill power to the screen until she gets around to fixing this or whatever? Would killing power to the screen kill power to AC controls or something else? Any help would be greatly appreciated.
Thanks,
jb
Thanks,
jb
Registered but harmless
Received 1,149 Likes
Or are you referring to the audio settings shown on the navigation screen?
If there is no damage on the DVD, then try cleaning the reader lens-- see the thread at: https://acurazine.com/forums/audio-b...errors-873489/.
Will,
With regards to the radio, it's the actual radio lighting. It's weird because the rest of the console and the display screen above the air vents are fine. The navi screen is black expect for the green "check your disc." I told her I would look at the disc drive itself the next time I see her. I hadn't been in that car in over a year. She's not taking care of it like I did. The poor thing... Thanks for the response!
"Burned bulbs" is probably the answer if the audio system otherwise functions fine.
I have the same problem with this too. I've been in the process of replacing all of my bulbs to LEDs, and I wanted to tackle soldering the radio bulbs next. The entire console and display screen work fine, but just the radio controls area (presets, tape deck, CD area, etc.), which is the lower half of the center console, have stopped working all together. It only lit up about half way a few weeks ago and then when I took the radio out to install my iSimple, none of the lights worked when I plugged the radio back in.
Did you ever find if there is a specific fuse connected to just those lights by any chance?
Will,
ivegotthenav
09-11-2015 07:51 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
Gianni Formica
09-07-2015 08:28 PM
