TVandNav2Go, Mediagate MG-25P, and PIE X3 Installed
Old 03-30-2007, 07:38 PM
  #41
datmrman's Avatar
I guess you missed my post in the other thread:
Originally Posted by RidinDurty
*Avox Jukebox
*HITACHI 120 GB could somone please click this link and show me exactly which one out of the 20 they list? They have some 3.5" and 2.5".
*Archos Car Adaptor
*Gefen IR Extender
Then I guess I need the RCA/wall plug. Is there anything I missed?
Ok actually BEFORE anything let me explain my plans for this set up in my car. I own a 2nd gen TL non Navy. I am looking forward to buying the dash/AC parts from the 02-03 Navy....
Originally Posted by datmrman
You will want the 2.5" hard drive. You have the mediagate part down. But you have a few more things to worry about after that. This also applies to the 3G TL.
Once you get your non-nav to nav conversion complete, you will need to look at getting a video interface to interact with your new navi screen (provide the video RCA connections you need). Fortunately, Dom's TVandNav2Go is also compatible for your car. If you don't know what that is, please perform a search.
Other than video, you will also need an audio interface to interact with the factory sound system. There are a couple available for the 3G (PIE, USA Spec, Blitzsafe), but I am not sure what works with the 2G. This audio interface needs to provide the audio RCA connects.
The combination of a video interface and an audio interface will provide the RCA connection you need to use the AVOX or any media player (DVD, iPod video, carPC).
Now, if you replace the factory head unit with an aftermarket one with RCA connections, problem is solved and you don't need to worry about these interfaces.
Hope that helps.
I don't think you've really read the threads either.
Check out the 3G TL Audio & Electronics FAQ for instructions on accessing the plug behind the headunit.
Old 04-01-2007, 01:07 PM
  #42
rookie1011's Avatar
datrmman
Thanks for the re-post...I am trying to follow the threads, it just seems that everyone posts different tactics and yours was the one similar to the way i wanted to install. I'll figure it out tho...thanks
Old 05-16-2007, 09:09 PM
  #43
awin's Avatar
datmrman...quick question...i got my pie x3 today...do i have to removed the nav...or can i just get to the plug through the glove...
Old 05-17-2007, 03:21 AM
  #44
datmrman's Avatar
, you do not have to remove the navi screen. Its a tight squeeze, but you can get to the back of the head unit by removing the driver's side kick panel. Some details here: DIY: Backup Camera with Dom's TVandNav2Go PNP Install.
Old 05-17-2007, 07:46 AM
  #45
Top_Shotta's Avatar
Any one in Toronto can do this for me?
Old 06-06-2007, 04:39 PM
  #46
FSU-Acura's Avatar
Has anyone found a legitimate (where I will not have to stuff copper wire and where the MG-25P won't shut-off on bounces) power source for the MG-25P while in the car?
Old 06-06-2007, 08:14 PM
  #47
lanceb1b's Avatar
Just a heads up but newegg is out of stock on the Avox Jukebox, I actually spent 2 hrs reading that thread. Mediagate /clone still the hightech toy in this area, anything else?
Old 06-07-2007, 01:30 AM
  #48
datmrman's Avatar
There are several types of these hard drive media players out on the web. It just depends on what you are looking for.
As for the AVOX, it is just a rebrand of the AL Tech mediagate which is available through stores such as eWaggle.com
Old 08-10-2007, 10:58 AM
  #49
Binx57's Avatar
RCA Inputs-GPS
I have been looking to replace the GPS unit in my 07-TL S due to it's inaccuracy and a list of functional issues that are fairly long (see this site for issues encountered by several members). Garmin makes a full function GPS unit as an after market install that is able to utilize the current TL screen as long as it has RCA inputs. From your post I gather you were able to use the current TL Navi screen inputs and that they are standard RCA jacks (Left Channel Audio, Right Channel Audio and Video). If I missed that aspect in your post, sorry. Could you let me know if you used the standard TL Navi screen input (regular RCA jacks or if you had to buy an adapter cable. Depending on how you connected to the display screen, I am going to see if I can disable the current 07-TL S GPS and install the Garmin GVN 52. Members can search Garmin for info on this unit. Thanks for your time, as a new member, I appreciate it.
Old 08-10-2007, 09:08 PM
  #50
datmrman's Avatar
You will have to buy an adapter to tap into the navigation screen. Please see the 3G TL Audio & Electronics FAQ and look for "TVandNav2Go."
This module is just a video interface. If you would like to integrate audio, you'll need to look at an aftermarket interface (DICE/USA Spec/PIE/Blitzsafe) or use the built-in aux-in from the '07. Details can also be found in the FAQ.
Good luck and please post pics of your install when you have it completed.
Old 12-10-2007, 08:34 PM
  #51
stgdsie's Avatar
i have this setup but i am not getting any audio input anyone have any way to help me fix this problem
Old 04-22-2008, 09:19 PM
  #52
jswong's Avatar
quick newbie question? I'm tring buy a pie x3 from ebay and it only states for acura tl 04- 05.... I have an 06.... will it work.... thanks
Old 06-23-2008, 11:01 AM
  #53
4th Gear
gfresh35's Avatar
Help
Anyone lives in San Jose area? I've been reading threads but I think I'll need help on installation.
Old 06-24-2008, 01:08 PM
  #54
jswong's Avatar
i'm an hour and a half away and also looking for someone to help me? got all the parts just waiting to install. what year is your tl
Old 06-25-2008, 10:15 AM
  #55
4th Gear
gfresh35's Avatar
I have a 05 TL. did you get the backup camera too? and where did you get the TVandNav2Go and PIE X3? I need to purchase those soon.
Old 06-25-2008, 02:53 PM
  #56
jswong's Avatar
tvandnav2go.com $250 + $15 shipping (Dom's video interface)
Ebay $60 + $12 shipping (pie X3 audio interface)
I didn't get the back up cam yet but you can also find that on ebay as well.... they are about $120 + shipping.
anyone out there put the pie x3 on an 06... not sure if it fits
Old 06-25-2008, 03:01 PM
  #57
jswong's Avatar
pm you
Old 02-05-2010, 06:09 PM
  #58
TallDarknFugly's Avatar
Is this still the best approach to getting MP3 in the TL or there have been better alternatives since 2008?
Old 07-18-2011, 04:01 PM
  #59
5th Gear
soccerman7410's Avatar
Power Tap
So I'm kind of a newbie to electrical wiring
I'm about to install a PIE X3 and Dom's unit
I'll tap power with a mini add a circuit in fuse 32
Just to be sure:
Can that set-up handle both the pie x3 and the tvandnav2go just fine?
I took classes on this stuff in highschool a few months ago but it's a lot different in real world application
Thanks,
Mitch
Old 07-19-2011, 02:39 AM
  #60
datmrman's Avatar
@soccerman7410, if you want the ability to add a backup camera, then I would install Dom's unit in the trunk. Both devices require very little power so I would say that yes, you can connect them to the same mini add-a-circuit at fuse 32.
soccerman7410 (07-25-2011)
Old 07-19-2011, 10:34 AM
  #61
Balling in the...
Mafyoso's Avatar
Hey where Can i Buy that media Player HD you have, that Avox Jukebox. I look at all the links you have on https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/my-secret-media-player-revealed-mediagate-mg-25p-598448/ but no one has it.
Old 07-25-2011, 12:02 PM
  #62
5th Gear
right, I was planning to put Dom's unit in the trunk and just run power from fusebox.
So what size fuse (i don't know if "size" is the correct way to qualify fuses) should i put in that add-a-fuse?
Been reading all your input on this process across Acurazine and it's extremely helpful dude.
I wanna make a sicknasty post about my install pretty soon and I want to make sure I know as much as possible about the process before that. So far I've spent under 150 bucks on my PIE x3, Dom's unit, and all the components! Fck yeah!
Old 09-24-2011, 02:49 PM
  #63
5th Gear
nasa_dork's Avatar
Old 10-01-2011, 06:24 AM
  #64
swp_king's Avatar
nice install where can i get all the stuff to do this to my tl
Old 01-06-2012, 09:54 AM
  #65
ExclusiveTL's Avatar
i just wanted to know since you changed from the pie x3 to the i-simple do still have the videos showing through your navi screen along with the factory control?
Old 01-11-2012, 03:33 PM
  #66
datmrman's Avatar
@ExclusiveTL: The iSimple and PIE X3 are audio interfaces; independent of the video interface. With the iSimple, I am able to control my iPod (for audio) through the factory head unit and steering wheel controls. If I want to have it display video from the iPod, then it would need to connected with RCA plugs where video is through Nav2Go and audio is through iSimple. In this auxiliary mode, you lose the controls and track text display.
cycdaniel
12-17-2019 10:58 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
pistacio
09-26-2015 09:45 AM
TxRzrBk
09-17-2015 01:07 PM
Quick Reply: TVandNav2Go, Mediagate MG-25P, and PIE X3 Installed
