Trying to Wire LOC...need 1 issue resolved
Old May 30, 2007 | 08:47 PM
Magicucf's Avatar
9th Gear
I am trying to install aftermarket sub/amp and connecting to factory system thru a LOC (line out converter) at the factory sub. Sub has 2 wires, + & - 2 channel LOC has 4 wires & ground. Where do I connect the LFT & RT wires to only one set of speaker leads?
Old May 30, 2007 | 10:03 PM
King of Pain's Avatar
What LOC do you have? Sounds like you have a 2 channel LOC. Did the LOC come with instructions?
Old May 30, 2007 | 10:22 PM
Magicucf's Avatar
9th Gear
Yes its 2 channel. Its a Stinger LOC. I have seen many people on this forum say they have used it and hooked it directly to the sub speaker wires that run to the sub. And of course directions say hook left channel plus & minus, as well as right. When you use the sub, how exactly do you wire it if the sub only has 1 channel. I just wanted to know that info.
Old May 30, 2007 | 11:05 PM
Magicucf's Avatar
9th Gear
I believe I found the answer. Since the LOC is 2 channel, you can just splice both negatives together and both positives together from each channel off the LOC to go directly to the one channel from the stock subwoofer. Can anyone else verify this is correct???
Old May 30, 2007 | 11:07 PM
SSM6MTNAVI's Avatar
Weather Watcher
^Hit the nail right on the head buddy. Thats right. Now go connect it and come back let us know how it sounds. Wot u puttin in?
Old May 30, 2007 | 11:23 PM
Magicucf's Avatar
9th Gear
Single JL 12w6v2. Sealed custom build enclosure, kenwood class D mono 600watt amp. Will have installed over the weekend. Also dyna matting from rear half of car from rear seat thru trunk.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Barb Jackson
Sep 15, 2015 02:27 PM
kuzdu
Sep 10, 2015 08:42 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
