Top Left Section of Steering Wheel-Electronics Died
Old Apr 24, 2012 | 07:27 PM
travv's Avatar
Smile Top Left Section of Steering Wheel-Electronics Died
Hi all,
I have an '06 AM at about 50k miles which has been treating me great.
Unfortunately the top left portion of my steering wheel electronics have stopped functioning... (VOL , CH, and MODE) I've attached a pic for reference
-The 'down' portion of the VOL button no longer "clicks" or "pushes" in...it's almost as if it's stuck. I can still click/push the top half of the VOL button, it just doesn't do anything
-The bottom 2 buttons still work (the 2 bluetooth phone icons)
-Also, it seems that the lighting has gone out on the VOL/CH buttons but MODE still lights up
-If it matters, I've seen lots of threads about bluetooth failing and replacing the module (my searches resulted in threads about bluetooth or iDevices)...I don't care about the bluetooth, I just want the volume and seek/skip buttons to work again!
Any input or advice would be greatly appreciated !
Thanks,
Travis
Attached Thumbnails Top Left Section of Steering Wheel-Electronics Died-photo.jpg
Old Apr 26, 2012 | 12:36 AM
NJAcura2004's Avatar
Sounds like you need a new switch. They're cheap if you buy them from a dealer online you'll usually get wholesale pricing.
Old Apr 27, 2012 | 08:33 PM
travv's Avatar
A new switch? as in an electronic switch or the actual volume button (which i don't think is the problem)
Would you mind elaborating on this switch?
Thanks a lot!
Old Apr 30, 2012 | 06:57 PM
travv's Avatar
Anyone else have any experience with this sort of issue?
Old May 1, 2012 | 09:42 PM
DeathMetal's Avatar
Fearless DIY Guy
The assembly is held in place by 3 screws behind the SW and can be remove once the airbag is out...it's pretty simple. From there, there will be 3 more smaller screws to remove the silver housing. Take the housing off and inspect for debris. If there's any damage to the button dimensions and lever, you'll see if right away - it'll be readily apprent.
From the factory, there's a fine film of lube on the perimeter of each button...sounds crazy, and I am not shitting you, but you may just need to lubricate them
Old May 8, 2012 | 07:36 PM
travv's Avatar
Thanks for the response. Removal of the airbag is a simple process?
I think i'll look into doing this but it seems a little more complicated than you make it sound! I would be surprised if this was an issue of something preventing the buttons from function, since only the 1 end of 1 button sticks...but I would be happy if this was the actual issue!
james357
Feb 13, 2016 02:37 PM
Frathora
Sep 28, 2015 11:29 PM
Sep 17, 2015 10:16 AM
jordanboi
Sep 5, 2015 01:33 AM
