Is there a relay to do this?
Old Feb 13, 2010 | 09:04 PM
bzyrice's Avatar
I want a relay that switches something on when something else turns off.. Is there a type of relay that does this?
Old Feb 13, 2010 | 09:35 PM
nfnsquared's Avatar
Depending on the on/off nature of the devices, a simple SPDT relay could do it. The device that shuts off would have to de-energize the coil (terminal 85 or 86) by cutting either + or - voltage to the coil. Your device that needs to be turned on would be connected to terminal 87A. A power source (either + or -, depending on what you wanted to use) would be connected to terminal 30. When the coil is de-energized, the relay opens, connecting terminal 30 and 87A to close the circuit, turning your other device on.
Old Feb 15, 2010 | 10:43 AM
bzyrice's Avatar
awesome thanks!
Just found out about the 5 pole relays.. here is a diagram I found on mp3car.com
More info on relays is here.. man, I learned alot from that read lol
http://www.mp3car.com/vbulletin/faq-...w-wire-up.html
Does it matter if pin 87 has nothing attached to it?
Old Feb 15, 2010 | 10:57 AM
nfnsquared's Avatar
Nope, not at all. If there is a wire or lead attached to 87, remove it or wrap the end well because it will be "hot" whenever the relay coil is energized.
Some other good links (sorry, should have given you these earlier):
General relay info
Relay forum
Relay special applications
Old Feb 15, 2010 | 01:09 PM
dwb993's Avatar
I can't wait to see what you have up your sleeve with this one!
Old Feb 15, 2010 | 06:29 PM
bzyrice's Avatar
General relay info
Relay forum
Thanks man!! Those are good reads also!
lol.. nothing crazy.. I am actually out of mods to do right now lol .. I was thinking about adding a blinking led that looks like the viper alarms..
Jamus22
Jun 11, 2023 10:08 AM
01CLOwner
Oct 9, 2015 01:07 PM
Kres43
1G RDX (2007-2012)
Oct 3, 2015 07:16 PM
greeneyes.hypnotize
Sep 27, 2015 02:47 PM
Ty-Sama
Sep 21, 2015 05:45 AM
