Is there a relay to do this?
Depending on the on/off nature of the devices, a simple SPDT relay could do it. The device that shuts off would have to de-energize the coil (terminal 85 or 86) by cutting either + or - voltage to the coil. Your device that needs to be turned on would be connected to terminal 87A. A power source (either + or -, depending on what you wanted to use) would be connected to terminal 30. When the coil is de-energized, the relay opens, connecting terminal 30 and 87A to close the circuit, turning your other device on.
awesome thanks!
Just found out about the 5 pole relays.. here is a diagram I found on mp3car.com
More info on relays is here.. man, I learned alot from that read lol
http://www.mp3car.com/vbulletin/faq-...w-wire-up.html
Does it matter if pin 87 has nothing attached to it?
Nope, not at all. If there is a wire or lead attached to 87, remove it or wrap the end well because it will be "hot" whenever the relay coil is energized.
Some other good links (sorry, should have given you these earlier):
General relay info
Relay forum
Relay special applications
General relay info
Relay forum
General relay info
Relay forum
General relay info
Relay forum
lol.. nothing crazy.. I am actually out of mods to do right now lol .. I was thinking about adding a blinking led that looks like the viper alarms..
Jamus22
Jun 11, 2023 10:08 AM
