System installed -Help-
Well my audio system is in but I need to check the installers work. I do have a few problems. Beach Audio wanted 3600.00 to do the job with a Bit One. But I found someone to do it for 1450.00 and use the 3sixty.1 I have,
I'm mostly satisfied with the work I do have some issue's.
1. which fuse circuit is the best for the remote turn on? (i've searched ) I have the 07 TL S
2. my keyless entry stops working after I leave the car & lock it. the deal is the alarm goes off when I open the door with hard key(the remote stop working) I get in the car start it, turn it off, pull the key out & now the remote unit works, but after 2-3 minutes away from the car it no longer works It think the boozo tap some wires he wasn't to.
the 3 way's in the doors look good & the 3 ways on the rear deck and the 3 apms in the trunk turned out nice, I'll share some pic's later this week. All the info on the board help eminencly
no fuse circuit...always tap ignition harness...accy wire...
dunno how someone screws up factory keyless while doin an audio install...
looks like u got what u payed for my friend...bring it to palmdale and i'll fix it
-Jason
-Jason
cycdaniel
12-17-2019 10:58 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
