System ground annoying buzz
So I just did a full sound system in my 08 TL ua7 about a week ago and the installer is a buddy of mines who has done several of my friends tls and I went all out. Audio control lc6 Wired to components replaced the factory sub with a 8 inch ev powered by two Jl amps and a w6 Wires are 2 gauge JL cooper plated dual amp kit. All rca are monster cable rcas
Anyhow.... here's my issue There's an immense buzz coming when the volume is low or even off. The installer told me its from the blue tooth mic and when he removed the rear mic the ground buzz lowered. When he went to remove the front blue tooth mic I told him no. And he told me he removed it from my friends cars and it worked for them
Has anyone else have this problem. And or knows a solution where I can keep my blue tooth and killing this ground Issue????
so no one has any clues on what this could be??? is it related to the blue tooth mic like the original installer said? HELP this feedback is driving me crazy!!!!!
I just did the same thing on my 08 tls, I diconnected the rear anc mic, its above your rear interior dome light, it will be a green clip towards driver side once you take off the plastic, you need a Phillips screwdriver as well.
i unplugged that mic already, though the noise reduced significantly it hasnt completely gone away... at the recomendaion of another thread im going to try and change the high low convertor to something more basic. My only concern is that the amps stay on after the car has been turned off! the audiocontrol lc7 has a shut down for the amps and idk if the more basic high low will do the same thing
Codename Duchess
Did you try switching the grounding jumper in the LC7?
There are two mic's in the car that have to be disconnected and no, you will not lose your ability to send/receive calls over bluetooth. You will have to unplug both the front and rear mics to eliminate that buzz.
The type S has a noise reduction system that reverberates the factory sub as it picks up noise with both mics in an effort to trick the ears of passengers into perceiving the noise to be reduced. Both mics are for that system. There is a much more technical explanation than that but that's the basic overview of it.
Yes I changed the factory tweeters. Put Jl components in there ran directly to speaker wires ran to the crossover then to the amp directly
Factory amp was disconnected last I checked but I'll double check with the installer this weekend as that is a good reason I can be having this problem also
Thanks guys for the feedback so far and happy thanksgiving
The bluetooth mic is elsewhere. I had the same buzz you are talking about and it drove me nuts for almost a month trying to figure out what was going on. The crazy part is my best friend is an installer and has been for over 15 years and another friend who is also an Acura tech and has a TL - the 3 of us were stumped until the tech friend found out what was going on after some research.
After disconnecting both mic's I now have no issues with my aftermarket amp/subs and can still use the bluetooth without issue. You only have to unplug the 2 mics and will be able to plug them back in later should you decide to go back to stock. This is only an issue on the Type S from what I understand.
PS - I also have a KBP. Yours is looking good!
romeotl3 (12-03-2014)
joflewbyu2
10-08-2015 11:16 AM
