subwoofers
Old Jun 14, 2010 | 11:37 AM
lextl2006's Avatar
subwoofers
i want to see your subwoofer setup
Old Jun 14, 2010 | 12:20 PM
CLtotheTL32's Avatar
12" Alpine Type-R 4-ohm
Rockford Fosgate 500.2
Rockford Fosgate 4 Gauge Wiring Kit
Uncald4 Fiberglass Box
Old Jun 14, 2010 | 12:23 PM
wrxyboy's Avatar
1st TL-S on air in
how do you like the uncald fiberglass box. I am unsure if will handle the sub id like to run.
Old Jun 14, 2010 | 12:26 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It's only recommended (by me), if you want to have usable trunk space. For performance, it's not highly recommended (by me).
Old Jun 14, 2010 | 12:27 PM
Now, having said that, I have the same setup here:
Here is the original miracle box
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/system-works-686412/
Here is a mini version.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/mini-dreambox-build-%3D-decisions-decisions-2ohm-4ohm-dual-single-coil-763323/
wrxyboy's Avatar
1st TL-S on air in
performance as in racing or performance of the sub enclosure.
Old Jun 14, 2010 | 12:29 PM
^sub enclosure.
From reading the threads that I posted. The TL's trunk isn't designed to carry sound waves into the cabin. By building the miracle box, the sound enters the cabin through the backseat.
Old Jun 14, 2010 | 12:31 PM
This vvv:
^sub enclosure.
Old Jun 14, 2010 | 12:34 PM
wrxyboy's Avatar
1st TL-S on air in
i guess my only route is to take it to a shop to build a custom box so i can still retain some trunk space plus all my air parts.
Old Jun 14, 2010 | 12:38 PM
Or, you can use uncald4's box. It has superior "usability". I can even access my spare tire well with no problems.
Old Jun 14, 2010 | 12:42 PM
wrxyboy's Avatar
1st TL-S on air in
^^^ thing is the sub i am looking at is pretty big and i dont know if it will fit in the uncald4 box. I guess i better do more research on the uncald4 box
Old Jun 14, 2010 | 12:44 PM
What sub are you going to use?
Old Jun 14, 2010 | 12:45 PM
I don't want to derail the OP's thread, so this will be my last OT post: Don't think about putting anything bigger than a 10" sub in the box.
killersrt's Avatar
I believe he makes each enclosure specific to the sub you use
Old Jun 14, 2010 | 12:47 PM
This is absolutely true, but refer to post #14.
Old Jun 14, 2010 | 01:24 PM
Sound Murderer's Avatar
New York state of mind
Old Jun 14, 2010 | 01:31 PM
Old Jun 14, 2010 | 02:30 PM
cjTL's Avatar
I'm Craig
Yeah that's pretty sexy. Your username is fitting. Haha.
jptl04...get your ass in here!
Old Jun 15, 2010 | 02:11 PM
2K2SilverTL-S's Avatar
AZ O.G NoOldManVetteOwner
Old Jun 15, 2010 | 02:39 PM
^Uh this is in the 3G TL section I hope you know.
Old Jun 15, 2010 | 02:44 PM
^dont worry he knows. he has a 3G
but likes to show off his vette.
Old Jun 15, 2010 | 03:35 PM
eggyhustles's Avatar
uncald has nice boxes but most of you guys are stuffing subs that belong in bigger enclosures
Old Jun 15, 2010 | 03:38 PM
, including myself.
Old Jun 15, 2010 | 03:44 PM
so u spent 200+ on a box that isn't meant for the sub?
Smart.
Old Jun 15, 2010 | 03:48 PM
Smart.
Actually, I spoke with Travis directly over the phone and he recommended the exact sub that I have, for the box that he was fabricating for me. He knows his stuff, so I went with his exact recommendations.
Even a 6" sub potentially wouldn't be fully utilized in that box. Maybe he'll chime in for his .
My goal was functionality and performance, with an emphasis on functionality. Hence why I went with this specific enclosure.
Old Jun 15, 2010 | 03:53 PM
I hate cars's Avatar
I've got 2 12W6s in a bandpass ported into the cabin, no bass in the trunk. This is truly the only way to play it at high volumes without worrying about rattles.... and it's so much more efficient. This is the best sounding system I've ever owned and it goes louder than anything I've ever owned. Too bad CSWBiggs is not on here to post pictures of the original. I'll take some pictures this afternoon. I went to get the camera to take pictures and found that the GF had it with her at work so it will have to wait.
Here is the original CSW build which is what I copied. Mine looks much more ghetto as it was my first attempt at building a box.
Old Jun 15, 2010 | 04:06 PM
Souljah's Avatar
Former Whiner
Originally Posted by Sound Murderer
Winnar...
And you didn't even have to mention you're a doctor!
Old Jun 15, 2010 | 05:06 PM
Case in point
SPL woofers in small sealed boxes
Subs that belong and perform best in big ported.
1 of those in the right box would be louder and sound better than the box they're currently in.
Old Jun 15, 2010 | 05:10 PM
Case in point
I agree the box is likely too small (hard to tell by looking at it) but it does look to be ported on either side.
Old Jun 15, 2010 | 05:15 PM
That's a port?
That box is def too small
If they were ported, the 15 needs about 6 cubes after port and sub displacement.
Old Jun 15, 2010 | 05:23 PM
That's a port?
Yep. Probably too small for a sealed, even worse if it's ported.
Old Jun 15, 2010 | 09:07 PM
all the hate on my bass
haha but do you think its really too small?? i had it done at a shop here in south florida and the guy def knew alot and we decided what would be best for what i wanted...but i dont know shit about installed boxes and what not so do you guys think he fucked it up?
i spent a bit of change on this so id like it right >
Old Jun 15, 2010 | 09:12 PM
apparently, he didn't know shit.
those subs need MASSIVE sized boxes to perform properly.
Honestly, even with 2 12's ported, u wouldn't be able to fit the proper enclosure in that trunk.
If u want to do it right, ditch them for better spl subs.
If u like it, keep it the way it is.
But do know that they can sound way better and get alot louder in a better box
It really pisses me off when shops take advantage of folks who don't know much about audio.
Old Jun 15, 2010 | 09:13 PM
How do you like the sound and performance?
Old Jun 15, 2010 | 09:38 PM
hmm how massive does it have to be? could one be in the same box and work?
it sounds pretty fucking loud and clear as is, way better than my ported kicker box in my honda
the sound from the box is BIG and clear/smooth so he cant have messed it up to bad
my only qualm is the lack some high bass in the old school jungle tunes i play often, was thinking of getting another smaller sub
thoughts?
Old Jun 15, 2010 | 09:46 PM
higher notes? screams lack of midbass.
How's your front stage looking?
1 may be able to fit.
the 15 calls for a minimum of 3 and a maximum of 6 cubic feet for each.
You should aim for around 4 cubes after port and sub displacement.
Old Jun 21, 2010 | 09:20 AM
mendii310's Avatar
7th Gear
This is an old pic, since then i put in a 2400 watt orion amp on the floor behind the subs and tinted the tail lights darker.
3 - 12" pioneer premier subs
2400 watt orion competition amp
Old Jun 21, 2010 | 09:56 AM
Acuraluvr's Avatar
Spinnin them beats
Uploaded with ImageShack.us
:shurg: Simple, works. But i REALLY want a smaller box. Cant get my spare tire and its simply too much space. Its a 12w6v1... think i can get unclad's box?
Old Jun 21, 2010 | 03:50 PM
King of Pain's Avatar
Here is my last set-up but I changed some things around since then.
TC Sounds TC-1000 in a small sealed box with an Alpine PDX.1-600 for power. Nothing flashy just clean sound
