SubWoofer Facing...
Old Feb 21, 2008 | 01:18 PM
clavodulce16's Avatar
[PA] NBP-TL
SubWoofer Facing...
which way should i have my subwoofer facing. I have a 12'' Pioneer powered by a Alphasonik Amp.
My question is. Which way should i have the sub face. Inside in to the car or facing the outside (meaning if i open my trunck am going to the the pioneer sub moving.
Let me know whihc way might sound better. and whihc way you guy have it
Old Feb 21, 2008 | 01:33 PM
phee's Avatar
I got the Shifts
Face it outward, it gives more space for the bass to mature and give you the right sounding notes.
Old Feb 24, 2008 | 01:13 AM
BukvaMan's Avatar
If you want it accurate and really good sounding then u want it facing forward trough the armrest opening. But u gotta make sure when u put in the box that way that u seal around it so that all the bass goes into the cabin and not back to the trunk wich would cause a lot of cancelations and u would lose sound. But then again the easiest way is to turn it towards the back..... I played with my setup for about couple of months and found out that facing forward gives me the best image and the best sound quality and also it gets louder belive it or not
Old Feb 24, 2008 | 01:32 AM
lowendz's Avatar
agreed with bukvaman, however, hearing and feeling the bass are two totally different things. most people like to feel it (low rumbling...) also, hearing it may now sound as pleasant, all it does is makes your ears rattle. in reality, bass is most heard and felt when it has more surfaces to bounce off of (air waves). because you can barely hear sounds from 20 hertz to 35 hertz and is best felt from the low vibrations as long as your car is not rattling.
The reason why bukvaman's setup will work well, is because using the armrest opening makes the system similar to a bandpass setup (thats the reason it has to be well sealed around it), 2 chambers, one sealed, one ported(armrest opening).
otherwise, facing the rear, right against the back of the seats work great.
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
