Subwoofer
Old Jan 13, 2012 | 09:01 PM
mwhite28's Avatar
Subwoofer
Hey everyone,
I've recently bought a 2005 Acura TL about 2 months ago and I'm looking to upgrade my subwoofer, i'll worry about speakers next check. It already has an 800-Watt Amp in there, and I was wondering what do you think the best subwoofer would be to purchase.
I'm looking to stay within the 150$. Any less expensive that you feel is worth the money, send them my way. Any ideas?
Old Jan 14, 2012 | 07:36 AM
Ray.Collins's Avatar
800w max or rms? and 150 for a sub or for a sub with enclosure?
assuming you mean max and need an enclosed sub, http://www.sonicelectronix.com/item_...e-GTR1002.html is probably your best bet.
Old Jan 14, 2012 | 08:10 AM
EL_PIC's Avatar
Rich and Famous
The Renegrade has an attractive price but $100 is not a lot to spend
and online purchase can be risky.
Go to custom stores in your area and try them (pre enclosed)
in your car if you have the pre wire done.
The best way to test speakers {auto or home} is in
the exact accoustics they will play in andwith pre wired.
Some stores let you try them out and return exchange
within a certain time limit.
Old Jan 14, 2012 | 09:46 AM
jda123's Avatar
Dogmatic Dinosaur
For that kind of money, look around for used stuff on Craigs List. You ought to be able to find some stuff in the JL W3, Type R, etc. range.
Make sure that you know exactly what you amp can do before you buy. Post a brand and model number if you need help.
Old Jan 14, 2012 | 10:34 PM
eggyhustles's Avatar
Just for sub?
That price screams ssa dcon
Old Jan 25, 2012 | 09:39 AM
mwhite28's Avatar
Sorry its taken me so long to get back to everyone. I've always been into music and loudness with good bass but i've never had the honor of learning the electric aspect of it as in wattage and what not. So my Amp is 800W from what I seen, I can find out the model number next time I get out. What type of Specs should I be looking for in my subwoofer?
Would something like this work?
Pioneer TS W2502D4 Champion Series Pro car subwoofer driver - 800 Watt
Or would that blow it away?
Old Jan 25, 2012 | 09:44 AM
ohsixMTee's Avatar
Early Shifter
You really need to know the specs of the amplifier before you shop for subwoofers, report back with the model number.
It's extremely helpful to know it's power output at different resistance levels, that will help you choose a sub or subs.
Old Jan 25, 2012 | 09:46 AM
mwhite28's Avatar
gotcha i'll get all that later on, thanks appreciate it.
Old Jan 31, 2012 | 04:45 PM
mwhite28's Avatar
Finally had time to get everything found. It's a 800-Watt Maximum Power Kenwood, model number KAC-8403 (which I can't seem to find online). 60W ( RMS x 4 @ 40hms and less than 1% THD+NT.
Like I said, I'm very illiterate when it comes to audio statistics. Any suggestion on what to do?
Old Jan 31, 2012 | 04:57 PM
That amp is better suited for some speakers rather than a sub.
specs are
RMS Power @ 4 ohms 60 watts x 4 channels
RMS Power @ 2 ohms 90 watts x 4 channels
RMS Power @ 1 ohm Not Stable
Bridged RMS Power 180 watts x 2 channels
Old Jan 31, 2012 | 05:53 PM
mwhite28's Avatar
specs are
ok so what types of speakers are best suited for this amp then? Any suggestions
Old Jan 31, 2012 | 06:17 PM
Got a budget?
Old Jan 31, 2012 | 06:19 PM
mwhite28's Avatar
Got a budget?
well i wanted to spend no more than 150 or so for a sub, but for speakers I know it will cost a little more. I mean it's more of a don't want to spend a ton of money but don't want to spend any money on a crappy pair of speakers. Looking for Pioneers as thats what I've had the past but any will do
Old Jan 31, 2012 | 08:19 PM
I hate cars's Avatar
If you're looking for sound quality, the best money is spent on the front speakers.
Old Jan 31, 2012 | 11:38 PM
ohsixMTee's Avatar
Early Shifter
Something like this would fit the bill pretty nicely, http://www.onlinecarstereo.com/CarAu..._12W1v2-4.aspx.
Even JL's lower line stuff will sound pretty good. Don't expect it to shake the neighbors out of bed but it should fill the cabin with quality sound.
Old Feb 1, 2012 | 08:59 PM
mwhite28's Avatar
Will that fit into the stock sub placement? or am I better off building a box for that?
Old Feb 1, 2012 | 09:10 PM
hell no.
Old Feb 1, 2012 | 09:21 PM
mwhite28's Avatar
hell no.
hell no what lol
Old Feb 1, 2012 | 10:02 PM
Trunk Monkey's Avatar
Coolest A-zine Member
No. Stock sub is 8" and you don't want to mount anything, especially a sub on flemsy metal. Bad Bad
hell no.
hell no what lol
Lol. Eggy isn't too fond of JL. I've never heard the w1, but I've had the 10w3v3's and now the 12w6v2's and their solid subs. For $100, I'd look into something else though. With an amp that does 180x2, you're going to need a different amp for a sub. Look into a 5 channel if you want to power speakers later. Power is cheap nowadays! Might not be clean or reliable lol..but it can be cheap
Old Feb 1, 2012 | 10:19 PM
mwhite28's Avatar
so a 5 channel amp would be able to hold speakers and a decent sub?
Old Feb 1, 2012 | 10:21 PM
mwhite28's Avatar
well too make it easier, how much should I budget to upgrade everything?
Old Feb 1, 2012 | 11:05 PM
You could even do a power 4-channel. Meant to put 4 or 5 channel, not just 5-channel. Put that amp on craigslist and it'll probably bring your $50-75. You could pick up a powerful 4-channel, sub and box for now and be right around $300-350. Don't forget you'll need an amp kit for install. And installation..if you can't do it
Old Feb 1, 2012 | 11:30 PM
ohsixMTee's Avatar
Early Shifter
JL's are fantastic subwoofers, I've had multiple 12w3's personally and when properly powered they are extremely clean and accurate.
I do not have any experience with the lower line models but I would expect the same clarity with a little less volume than a W3.
And yes, separate enclosure is a must.
Old Feb 2, 2012 | 08:18 AM
w6's & w7's are fantastic subs
w3's, w1's, w0's? not too great
OP, spend a couple bucks more and get either a ssa dcon or a dayton ho.
Old Feb 6, 2012 | 11:15 PM
mpower1's Avatar
6th Gear
Jl gets my vote all day!
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
