Subs
Old Aug 1, 2013 | 11:11 PM
joe-gill's Avatar
8th Gear
Subs
is it possible to controll aftermarket subs from your nav screen ? plus can i run my stock sub with the aftermarket or will i have to disconnet it. ? if anyone can help me that would be awsome
Old Aug 2, 2013 | 01:29 AM
MarcoNorthPolo's Avatar
KCCO
You shouldn't run your stock sub with an aftermarket sub. It's best to unhook it in that case. It is possible to control an aftermarket sub from your head unit, I'll let someone with more knowledge than me explain how.
Old Aug 2, 2013 | 01:25 PM
Vlad_Type_S's Avatar
Registered Bike Offender
What do you mean by "Control"? If you use an LOC (Line Output Converter) to connect to your aftermarket sub's amp, you will retain the control of every feature on the factory nav screen. +1 on disconnecting your stock sub with an aftermarket setup.
Old Aug 2, 2013 | 01:30 PM
abirvalg's Avatar
remote gain knob is a handy thing
the HU will change how much lows a track plays, but it won't let you adjust the gain
it may be useful beyond the initial setup as well, depending on the range of music you enjoy
Old Aug 2, 2013 | 04:44 PM
KCCO
Yes, a remote gain would be awesome.
Old Aug 6, 2013 | 11:50 PM
joe-gill's Avatar
8th Gear
thanks guys ill unhook the stock sub.
but can i still adjust the after market sub level from the stock navi screen ? just like we use to controll the stock sub. like i don't want to hook it up to my rear speakers to adjust the after market subs bass level. im sorry im kinda new to this aftermarket stuff. idk if im making any sense here.
Old Aug 7, 2013 | 12:50 AM
Gil'sUA5's Avatar
No you cant control the sub level from your factory radio but like the other guys said, you can install a remote bass knob to control the gain from the dash without having to go to the amp to adjust it.
Old Aug 7, 2013 | 07:21 AM
abirvalg's Avatar
false
installing a sub will not disable HU's sub level control
a remote gain will no doubt provide a wider adjustment range, but once the gain is set to a reasonable level, the sub level will remain adjustable via sub control of the HU
Old Aug 7, 2013 | 08:19 AM
Gil'sUA5's Avatar
Originally Posted by abirvalg
false
So let me get this str8, the factory HU can control the gain on the aftermarket sub with an aftermarket amp like it does with the factory sub? Didnt think that was possible.
Old Aug 7, 2013 | 09:02 AM
abirvalg's Avatar
it doesn't contol the gain, it controls the level of the input signal
just like when you change the volume on the HU
Old Aug 7, 2013 | 09:24 AM
KCCO
^ Yup. It makes sense.
Old Aug 12, 2013 | 08:16 PM
joe-gill's Avatar
8th Gear
so is there an adapter that i will need ?
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
