Sub replacement
Old Apr 19, 2011 | 08:13 AM
mau108's Avatar
Sub replacement
Ya I checked the FAQ. But question, do you guys think if I drop in a JL 8" I will need to add an amp or can I use the stock amp?
I don't need it any louder then the way it is now but I'd like softer bass instead of the tight the stock speaker has. I may have to go with an external 12" but I'd like to keep the speakers as stock as possible and I really don't want to have to wire another amp to to new 8", I'd rather put in the 12 and wire external amp to it.
Thanks!
Old Apr 19, 2011 | 09:43 AM
jda123's Avatar
Dogmatic Dinosaur
Some people are happy with a shallow mount 8 in the stock location. You can amp an 8 in the rear deck, but the deck is not strong enough for too much power - maybe 100-150W at most, but I am guessing since I have never done it. Looks like you might have to go with a 12.
You have a noise canceling microphone in your S that you have to disconnect if you do all of this.
Old Apr 19, 2011 | 09:58 AM
mau108's Avatar
But is the stock amp capable of amping an 8" JL shallow mount sub ?
Old Apr 19, 2011 | 10:04 AM
jda123's Avatar
Dogmatic Dinosaur
Yes, with about 30 watts max.
Old Apr 19, 2011 | 10:38 AM
Trunk Monkey's Avatar
Coolest A-zine Member
I don't think the difference of adding a free-air 8" sub of the factory amp will be worth it. By the time you add deadening to the rear deck, you could have added a nice 8" sub with a small amp in a small sealed box and had double the output and a much better sound. You can always turn it down if its too much...can't turn it up without adding more power or distortion
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
niray9
Dec 8, 2015 07:34 PM
Billu99tl
Sep 13, 2015 11:30 AM
