Sub amp setting...question
Old Feb 4, 2007 | 10:13 AM
TSC17's Avatar
2012 SH-AWD / Advanced
I will be installing my NINe.2x to run a single 13ov.3 in my TL.
Since the .1 channel is handled by the OEM HU and is passing just LFE to it, should I set my amp to full as opposed to crossing it over?
My thought is that I shouldn't need to filter out higher frequencies, as the HU should already be processing this.
Thanks in advance...
Old Feb 5, 2007 | 03:09 PM
TSC17's Avatar
Come on guys...I know you're out there!
Old Feb 5, 2007 | 05:21 PM
BukvaMan's Avatar
the tl stock subwoofer isnt really ment to handle such low frequencies anyhow so its crossed higher more like a midbase id say well a little lower but u get my point so letting you new subwoofer pick up frequencies higher then 100 hz would be very bad sounding in my oppionon. u shouldnt have the LP crossover set higher then 80 hz for the subwoofer. it would be way to boomy!!
Old Feb 5, 2007 | 05:50 PM
TSC17's Avatar
Maybe I'll just play around with some test tones to see where the crossover points are for the .1 channel as well as the others.
4drviper
Apr 23, 2025 07:13 PM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
Pegon95
Sep 15, 2015 01:54 PM
