Stock audio system specs???
All Around Klown
Does anyone know the stock specs for the factorys system?
I mean everything like, speaker location and size, wattage, factory amp wattage, sub wattage.... anyone?
Bueller?
Bueller?
TLicious Type S
Here's a like to the amp wiring diagram if that helps.
https://i.imgur.com/yKOnV.jpg?1
I understand it's a Phillips amp, with some specs here: https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/details-stock-tl-amp-558485/
amp with not enough clean power
(4) 6.5 inch mids , (2) tweeters, 3-4 inch center, cant remember.... and an 8inch sub, all of poor quality
what else do you need to know
tnjwills (03-06-2013)
it's only one level up from this post and called a FAQ
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/3g-tl-audio-electronics-faq-605299/
https://acurazine.com/forums/showthread.php?t=605299
I don't mean to kick the FAQ section because it typically answers all my questions, but the speaker section is pretty lame. In the ELS thread there are lots of bits of information, though not concrete enough to make me feel comfortable. The upgrade/install with pics is awesome, something I will be doing in the future.
What I believe he is asking, is specs that can help him properly match the speakers. Such as Pioneer does with theirs:
TS-C520PRS
TS-C720PRS
Specifications
5-1/4”
6-3/4”
Maximum Music Power160 Watts
260 Watts
Nominal Power Handling30 Watts
60 Watts
Frequency Response35Hz - 32kHz
25Hz – 32kHz
Sensitivity (Efficiency)88 dB
88 dB
Impedance4 Ohm
4 Ohm
Mounting Depth2-1/4”
2-5/8”
Though the only reason to do this is a direct speaker swap, I wouldn't recommend it if you can afford not to. I had a cadillac with 4 - 5.25" component w/ tweeters, and 2 - 6x9" 2 way speakers in the back. I swapped the 6x9s straight up and noticed a small improvement, then I went and got premier 5.25"s and changed all 4 doors out AND amp'd them - holy fuck.
Evil, good luck finding the information, and if you do please PM me and let me know.
EvilJoker (03-27-2013)
DiamondJoeQuimby
09-10-2015 11:40 AM
