Stereo issues with aftermarket amp and sub
Old Jan 22, 2012 | 12:55 PM
rybruce33's Avatar
So I hooked up 2 12's and amp last night in my 04 TL. Hooked up the LOC and have power to amp and subs but its not playing nearly as loud as it should. I do know that we connected the brown wire which i now see isnt supposed to be connected. Anyone know if thats the for sure problem?
Any help is appreciated
Old Jan 22, 2012 | 01:11 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Gonna need a helluva lot more info to help.
What LOC? Is it adjustable? What amp? What are the settings on the amp? Are you sure the sub control on nav or non-nav unit is on?
Old Jan 22, 2012 | 04:32 PM
rybruce33's Avatar
Line out convertor (thats wired into the wiring connected to factory amp. subwoofer is at max of plus6. no nav. 1000w aftermarket amp 1ohm stable. nothing is wrong with aftermarket amp or subs.
Old Jan 22, 2012 | 04:35 PM
rybruce33's Avatar
LOC is a PAC model sni-35
Old Jan 22, 2012 | 06:39 PM
That's the same LOC I had in mine when I purchase the car. It's an adjustable LOC...so you might need to check that. I would venture to guess that it's turned all the way down. If you're getting volume, but it's not nearly as loud as it should be then this is my guess....
Old Jan 23, 2012 | 03:27 PM
rybruce33's Avatar
did u have all your wires connected? My buddy hooked that part up while i did the rest but he hooked up the brown wire and I looked in the directions and it said dont hook up the brown wire...
Old Jan 23, 2012 | 03:49 PM
rybruce33's Avatar
checked the LOC its all the way up on both areas...
Old Jan 23, 2012 | 05:30 PM
Not sure then. Mine worked fine and I had the adj. LOC at 1/2 on both sides. Do a little troubleshooting
Old Jan 24, 2012 | 01:13 PM
jda123's Avatar
Dogmatic Dinosaur
Is the sub channel turned up on your headunit?
Old Jan 24, 2012 | 02:57 PM
rybruce33's Avatar
Yea i got it fixed today. My buddy who hooked up the LOC hooked it up completely wrong! Im not good with wiring. I can run the power, rca, and sub wiring but not good with other electrical. directions on the LOC arent great either. Thanks for the help guys!
Old Jan 24, 2012 | 03:15 PM
jda123's Avatar
Dogmatic Dinosaur
Now that you have it all figured out, what kind of amp do you have?
The LOC will drop the signal at about 24 db/octave under 100hz. In short, then can really make the lows fall off fast.
Old Jan 29, 2012 | 04:55 PM
rybruce33's Avatar
Memphis 1000w
Old Jan 29, 2012 | 06:55 PM
I hate cars's Avatar
Is this proven with all LOCs? I ran a super cheap one for nearly 5 years and never had an issue down to 10hz. Even before the MS8 was installed, the lows were fine, once I went IB and started trying crazy test tones, the sub would go nuts on very little power with 10-20hz test tones. At 24db/octave from 100hz, it would have nothing under 50hz.
AndrewS
19
Mar 14, 2024 06:59 PM
snorf
Nov 4, 2019 06:44 AM
christopher1
3G MDX (2014-2020)
Sep 10, 2015 06:43 PM
Gianni Formica
Sep 7, 2015 08:28 PM
trinikidcl
Sep 4, 2015 12:56 AM
