Speakers are not working!
I'm installing an aftermarket head unit and I have and aftermarket amp and subs and I have the head unit all wired up and when I got to test it only the sub works no speaker sound! How do you fix this ? Please help need done asap
KCCO
If you don't know what an LOC is, then you really shouldn't be installing your own HU, amp and subs.
A Line Output Converter is used to convert a head unit's speaker outputs or the outputs of an oem amp into a signal that will drive the preamp inputs of a new amp. If your amp has high level inputs, then you don't need an LOC.
Registered Bike Offender
Lol dude we need a LOT more detail than that. What kind of amp do you have? What kind of speakers? What kind of head unit? If it was "all wired up" then I wouldn't expect a problem lol.
Tell us more about your setup brah.
I know what a loc is but I think I need to remove it to be able to get sound to my speakers. I'm not sure why they are not working. I have fusion sub with a built in amp to the sub, then I have Jensen 6.2 inch touchscreen head unit
What are you using to amp the speakers?
do your speakers work? are you using a wiring diagram?
AndrewS
19
03-14-2024 06:59 PM
sockr1
10-01-2015 01:31 AM
