Speaker ISSUE..HELP
Old Jan 28, 2012 | 01:02 AM
Zeus<3Acura's Avatar
Speaker ISSUE..HELP
hey was sup guys. heres the prob, when i drive my back left speaker makes a static noise when i hit bumps or the ride gets too shaky. weird thing about it is. the noise goes away if i lock and unlock the car. not a huge issue but its annoying having to lock and unlock car as I'm driving for static noise to go away. another thing. a speaker on the front passenger side began to do the same things. its only happened about twice though with the front passenger one. what kind of issue may this be? wiring?
Old Jan 28, 2012 | 08:30 AM
Project_CLean's Avatar
MMkay.
Does it do the same problem in every Audio option (CD,Radio,etc.)
Have you tried isolating the problem; sound to only one speaker (the one you suspect is bad) at one time? Could be a loose connection.
also you didn't specify which MY TL you have;or if you have Aftermarket audio components?
Old Jan 28, 2012 | 11:46 AM
it happens at any option, radio, bluetooth stereo, cd. etc. my tl is an 06 acura tl base automatic. and it only happens to the back left speaker, and happened twice or three in the front passenger one. thats why I'm wondering what can it be that now its happening to another speaker. and no aftermarket components. the owner before me did have a sound system but has taken it all off except for a capacitor (idk if thats how you spell it)
Old Jan 28, 2012 | 11:53 AM
MMkay.
i would try disconnecting that capacitor first;im not sure how he wired it but that could be causing some issues. Especially if he has it hooked up to the stock amp, should be something to look into if you don't have use for it.
Old Feb 9, 2012 | 07:57 PM
so heres a vid of the noise, I'm guessing its a faulty connection or messed up wiring>
Old Feb 17, 2012 | 01:16 AM
bump
bump!!
Old Feb 17, 2012 | 11:30 AM
CLtotheTL32's Avatar
I have the same issue but it's constant on every input.
I've read through multiple threads about the issue and I believe it's the stock amp.
Old Feb 17, 2012 | 12:07 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Stock Amp = THE DEVIL
I would get down in the passenger kick and check the connections. Check for loose wires, etc. I'm wondering if that could be a bad ground also.
Old Feb 17, 2012 | 12:19 PM
Thanks for the respond guys. so if its a bad amp that means that it can happen to any speaker not just one? because the rear passenger speaker on the left does this every time i hit a bump and occasionally i get the front passenger one and that sound doesn't go away even when i lock and unlock the car. im hoping to get a solution without taking it to a shop. maybe it could be bad wiring? owner before me had a system but he removed it before selling, all thats left is capacitor.
Old Feb 17, 2012 | 12:21 PM
I would remove the panel and look over the amp. Maybe a wire has come loose or something.
I have the static on all of my speakers on all the inputs so I'll probably end up buying a new amp. They aren't cheap
Old Feb 17, 2012 | 12:48 PM
This screams wiring mistake. Pull that passenger kick panel off and see if anything is spliced into or just left open.
CLtotheTL32- I'd go with a separate amp and just hide it. Plenty of amps that will fit under the seat(s), behind the liners in the trunk, etc. Not sure if you lose the HFL voice and Navi voice if you just remove it all together though.
Old Feb 17, 2012 | 12:58 PM
mind helping me out and showing me in some way where the amp is located. complete noob here. is it the panel by the passenger door, closer to where their feet would be?
Old Feb 17, 2012 | 01:32 PM
^Yep.
So I just went out to my car and checked everything out. Everything looks like it's in place; no loose wires or anything.
I only have static when the car is running. If the key is turned to the first notch (battery) or the second notch (start), the sound is perfect. As soon as the motor is turned on, the static is there and is only gone when the volume is turned down to 0.
Any ideas?
Old Feb 17, 2012 | 03:14 PM
niebur3's Avatar
Factory Amp
Old Feb 17, 2012 | 03:22 PM
Without a doubt? They are almost $300 and I don't want to drop the change if it's not a guaranteed fix.
Old Feb 17, 2012 | 03:23 PM
What about for my issue? Noise usually comes when I hit a bump
Old Feb 17, 2012 | 03:27 PM
I checked the panel and everything seemed good. No loose wires
Old Feb 17, 2012 | 03:28 PM
niebur3's Avatar
Bad ground in the Factory AMP....many have had this issue, myself being one.
Replace the amp and your problem should go away.
Old Feb 17, 2012 | 03:53 PM
How much would it cost for the amp and install?
Old Feb 17, 2012 | 04:06 PM
niebur3's Avatar
For a factory amp, look on ebay or call the dealer. Install is extremely simple.
Old Feb 17, 2012 | 04:13 PM
So bad ground with factory amp? why not trace down the ground? Or is my thinking not logical here?
Zeus - I would also take the door panel off and make sure that your speaker has come loose from the baffle or something. Maybe what you're hearing is something moving when you hit a bump big enough. With reflections in the car environment, there's not telling EXACTLY where it's coming from or what the sound is unless it's decently loud. Taking the door panel off is super quick too.
Old Feb 18, 2012 | 12:01 PM
thanks dude but idk if you can tell by the video that its not something moving and more likely wiring gone bad. and probably when i hit a bump it causes the bad wiring to move which makes that staid noise and when i lock and unlock the car is moves it back? its happened on more than just one speaker also as i've said before, the left rear passenger and front passenger one. I' think what these guys are suggesting is the issue,bad grounding.
4drviper
Apr 23, 2025 07:13 PM
kb1rl
Sep 30, 2015 10:17 AM
polish_pat
Sep 25, 2015 12:24 PM
rboller
Sep 23, 2015 02:49 PM
