Sound deadening for rear seating area
Old Nov 25, 2012 | 02:38 PM
DC2many's Avatar
Sup zine, I have my rear seats out to adjust my dampening and left them out for the purpose of this thread
Does any sort of sound deadening material make a big impact where the rear seating area goes compared to other areas or is it not worth it. Should I just throw some stuff on there and put the seats over it as no one will see it
I just want to cut out overall necessary noise if possible and might as well start here
thanks
Old Nov 25, 2012 | 04:05 PM
05_NBP_TL's Avatar
HE>i
From the factory, the seats bottom actually has vinyl/foam deadner attached to the cushion part itself. Some deadning material is on the frame portion bellow the seat too from the factory.
When I deadned my whole car I had some MLV/CCF left over (sound deadner showdown products) that I layed under my seat for extra deadning. I just cut the vinyl and foam to fit and placed the seat back on top of it with no issues. I dont know how much it helped as I done my whole car at once, but Im definately happy with the results overall.
Old Nov 27, 2012 | 07:00 PM
DC2many's Avatar
I see, thanks. I'm guessing the wheel wells followed by pillars and doors create the most noise for our TLs?
Also I think the exhaust creates most noise on the right side, I feel as if my right ear is losing hearing... unless the only pair of headphones I have potentially running less noise on the right side
Old Nov 27, 2012 | 07:39 PM
05_NBP_TL's Avatar
HE>i
Yeah, my exhasut is tamed down alot now. I removed the seats and carpet and laid MLV/CCF on the entire floor. completely deadned the trunk and laid MLV in the spare tire well also. The doors are lined with deadner/MLV/CCF front and rear.
Old Nov 28, 2012 | 03:58 PM
DC2many's Avatar
I just called a audio store in the area, they carry some new good stuff that is a peel, stick, press
I remember last time I had to deal w/ sound deadening it was messy and heat was required.
I'll definitely gonna be doing this depending on how much my budget allows
good to hear exhaust noise went down too, I might be getting old I get irritated after a long period of time but it sounds so good I don't want to get rid of it. Just lessen inside noise
Old Dec 2, 2012 | 11:30 PM
DC2many's Avatar
Material used: has a thin foam with a rubber above it
I decided to do this because it was the easiest to do without having to take off too many panels and also back seats were out and I never roll with a spare set/tools. I carry a pump generator but will need a new one, current one busted
Helps to have a friend to help, time consuming to make/measure cuts. Incisions necessary to allow better forming/contouring to the frames chassis dips and elevations.
Both having not done this, I think it went pretty well and neat.
We got the spare wheel well floor to under the rear passenger seats. Laid it down cut some pieces out and fitted them as neatly as I could and made cuts to allow it to sit better and contour to the frame lines.
I think it somewhat lessened drone but I'm still getting an ear full from an all around radius. I have the rear seat bench in with cuts needed to get to bolt holes, seatbelt buckles, etc. No backing, perhaps with the backing in will it's true magic reveal. Or I just need to do way more of the car and/or exhaust is too loud
I bought way more than necessary, hopefully the audio place I bought it from will give me cash for the unused segments
Old Jul 19, 2013 | 06:17 PM
350's Avatar
350
My first ricer
So I started searching and this seems like the closest thread to jack instead of starting another. Has anyone deadened the rear doors? I know there's no speakers but going to close the doors they feel so light, would it make any difference in cabin volume or just be a waste of material and weight? I partially did my fronts and I think I'm gonna go back and do it right, just trying to decide if it's worth doing all 4 doors.
Old Jul 19, 2013 | 06:35 PM
pohljm's Avatar
deaden outside skin of rear doors just like front. inner skin is a bonus. I would hit the wheel wells and adjacent surfaces the hardest.
Old Jul 20, 2013 | 10:22 AM
05_NBP_TL's Avatar
HE>i
^+1
Old Jul 20, 2013 | 11:29 AM
MarcoNorthPolo's Avatar
KCCO
Every little bit would help. Use it wherever your pocketbook allows.
Feb 25, 2020 09:57 AM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
d.lim
Sep 15, 2015 08:54 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
