Some stereo questions
Old May 12, 2004 | 03:05 PM
mr_superlove's Avatar
Team WD Chaplain
Does anyone know of a way to cycle through the stereo modes in reverse? I typically toggle between the two XMs and the CD modes.
Also, what would be required to do away with one of the FM preset sets and the AM presets and replace them with two more sets of XM presets? With that many XM channels 12 presets is no where near enough. Do you think this would be possible?
Old May 12, 2004 | 03:35 PM
2XBling's Avatar
Can't be done. I'm in the same boat.
Old May 12, 2004 | 03:39 PM
caball88's Avatar
to go between xm1 and xm2 just say "radio select xm#".
Old May 12, 2004 | 03:42 PM
Talking
Easy- Put the transmission in reverse and then try it.
Old May 12, 2004 | 03:43 PM
Dutchml's Avatar
What's going on when I scroll through XM channels manually and it cycles between the presets. Such as turning the knob yields 10,11,12,..16 then back to 10. Started punching buttons and it fixed it, but don't exactly know what I did. I think it was the "mode" button in the audio screen.
Old May 12, 2004 | 03:47 PM
caball88's Avatar
:lol1: doesn't say that in the user manual.
Old Dec 31, 2004 | 11:07 PM
Team WD Chaplain
I'm bumping this in the hopes that someone has tried what I asked in the second paragraph since I posted it some months ago. Also, mods, if you wouldn't mind moving it to the appropriate forum. Thanks.
Old Jan 1, 2005 | 01:55 PM
jjtags's Avatar
I believe the mode button on the audio screen or the radio changes from category to channel (check the display near the clock and you'll see CH or CAT) and that probably limits the scroll range. If it's set to CAT or whatever is not CH (I can't remember exactly) then you will scroll within that category only and if it's set to CH, it will scroll through all channels.
Can anyone confirm my hypothesis?
4drviper
Apr 23, 2025 07:13 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
