Small cameras on side-view mirrors
Old 11-24-2012, 10:01 PM
  #81
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,652 Likes on 1,117 Posts
Freakin' turn signal voltages are messing this entire plan up!
So I hooked up the multimeter to the ORG/WHT and BLK turn signal wires again, and without the turn signals turned on, the DC voltage was at 0.5V. With the turn signal turned on, it dropped to 0.2V.
Old 11-24-2012, 10:57 PM
  #82
Codename Duchess
DiamondJoeQuimby's Avatar
Sounds like it behaves like a steering control wire. A resistance is applied when you engage the switch which causes a change in voltage that then signals the BCM to turn on the signal.
I don't know how elaborate you want to get here, but this is how I would tackle it:
1) Run the power wires and the video cable for both cameras in the car through the door molex by drilling or filing out the blank pin locations. You may have to cut and splice the video output in order to fit it through the plug since you won't be able to fit an RCA.
2) Power both cameras off of an acc power source so they are on with the key.
3) Use a PAC-TR7PRO
http://pac-audio.com/productDetails....&CategoryID=31
and use the actual turn signal pulse from the bulb (or wherever you can grab it, probably even in the mirror from the front mounted bulb) as 2 different inputs (left and right) for the TR7PRO. Program the TR7PRO to timed outputs for whatever duration you want to leave the image on the screen. Program the inputs as (-) "pulse", program the outputs as "timed" one (+) one (-).
4) Use the outputs of the TR7PRO to trigger your video input device. The VCIHON1 I sent you the PM about would allow this to work. Use one output as the the (+) trigger to the "reverse camera/video 2" input on the VCIHON1 This one will . Use the other output of the TR7PRO to trigger the (-) "Video 1" input on the VCIHON1. The trigger that trips the "video 1" input will act like the switch by providing a ground so video 1 is displayed. The trigger that comes off of the TR7PRO for the 2nd camera, running on the "r-cam/video2" input can be programmed as a positive to behave like a back-up camera, displaying that particular camera image on the screen.
The drawback to this is that if you turn on your signal that image will be displayed until the TR7PRO times out which may be longer or shorter than you want it on that particular instance. If you can live with that, you are golden.
And if you want to go really nuts, you could program the other 2 outputs to trip 2 relays to interrupt the turn signal inputs going to the TR7PRO after the first pulse so it does not continue to pulse the input each time the bulb clicks on. At that point though, you are really just showing off
edit: you may even be able to time the inputs and outputs correctly to "cycle" the inputs of the VCIHON1 to display the image uninterrupted until the turn signal is turned off. That would be tricky though.
Old 11-25-2012, 01:25 AM
  #83
05TLbase's Avatar
heres the link to the manual...
22-98 pretty much says it data... the way I take it. PDFs in windows 8 sucks a$$ so I haven't went through it in any great detail so there may be an easier way.
I don't think you should attempt to flip that relay with a data signal. I would be thinking more along the lines of modifying the voltage going to the bulb to be constant for a trigger. The type of circuit is right on my tongue. Maybe just a large cap could do the job. Anyways if you do use a manual switch the mod loses all the "coolness" and practicality.
When I ran my speaker wire through the door I just drilled a whole right below the rubber grommet, cut a slit in the grommet and fed the wire threw and I did find out there is such a thing as wire lube that day and it makes all the difference in the world.
Old 11-25-2012, 01:31 PM
  #84
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
3) Use a PAC-TR7PRO
Sounds like a lot of work.
Old 11-25-2012, 01:48 PM
  #85
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I routed the video wire under the plastic pieces on either side of the car, and when I get some more time, I'll route the wires to the trunk in anticipation of getting the NAVtool unit.
The other thought that I had was that the blue wire from the NAVtool unit requires a 12V input. I cannot hook that up to the ORG/WHT turn signal wire because the voltage is too low.
This is getting a little frustrating now.
Old 11-25-2012, 04:50 PM
  #86
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I have two options at this point: try to figure out the electrical voltage thing or hook up the blue wire to the ACC socket (so the NAVtool unit would be on all the time). I would have to hook up a normally open (i.e. off) push button switch on each of the camera power wires to work that respective camera. My initial thought would be to open a small hole for the push button switches in the steering wheel switches, but taking off the steering wheel plastic is a bit daunting, especially since it requires a torx (I think) bit.
Old 11-25-2012, 07:27 PM
  #87
Codename Duchess
It's really not considering you are trying to make the stock system do something it was never designed to do and make it seem integrated.
Old 11-25-2012, 07:37 PM
  #88
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
This all would have been a lot easier had the voltages of the turn signal wires been 12V.
Old 11-25-2012, 11:39 PM
  #89
05TLbase's Avatar
22-199 on the manual has your answer.
Here's what I'm getting... 6 is always hot... and 2 and 3 provide a ground to activate coil. 4 and 5 and going to the bulb I believe and will fluctuate resulting in the ~10v the manual says is read.
If so unbolt fuse/relay panel T tap 2 and 3 respectively to your camera power and trigger wire.
Old 11-26-2012, 05:18 AM
  #90
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Bought the NAVtool unit.
Question. The blue wire to the NAVtool unit is a trigger mechanism to turn it on automatically, correct? If I connect that to a constant +12V source, like the ACC cigarette lighter wires, it will be on automatically and all the time, right?
Reason I'm asking is that if I cannot figure this out, I'm going to add two push button switches to the power wires of the cameras, and be able to turn then on with push buttons (from the steering wheel).
Old 11-26-2012, 05:21 AM
  #91
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I cannot access the link that you provided earlier. Do you have a scan of it by any chance? I assume this is the repair manual from Acura, not the Haynes manual.
Edit: Nevermind. It's downloading.
Double edit: Holy crap. Talk about the goldmine of the repair manual! Awesome! Thanks bro. I'm looking at this now and trying to understand what the hell you said.
Old 11-26-2012, 05:43 AM
  #92
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
So, let me get this straight. Wires 2 and 3 from page 22-199 say that the left +10V wire is pin 2 and pin 3 is the right signal? So those voltages don't fluctuate?
The other question is how do I hook up the wires to the relay if it's bolted in there?
Old 11-26-2012, 05:57 AM
  #93
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Another question: Shouldn't I tap into pins 4 and 5 and not 2 and 3 because 2 and 3 are AFTER the relay, so they should blink, correct?
Old 11-26-2012, 06:04 AM
  #94
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Picture of the relay.
Another thing: The cameras require 12V+/-10% (so 10.8V to 13.2V), not 10V. So we may be back to square one.
Old 11-26-2012, 08:17 AM
  #95
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Just spoke with an electrical engineer, and we may have figured this out using a relay and another microcontroller.
Apparently looking at the electrical diagram I made, I put the black probe on the wrong black wire (the wire going from the Combination Switch Control Unit to the Turn Signal Light Switch). I have to find another ground wire to put the black probe of the multimeter on, while the red probe goes on the ORG/WHT wire and the BLK/GRN wire (separately).
Old 11-26-2012, 12:04 PM
  #96
Codename Duchess
The blue + trigger wire is exactly that. It triggers the unit to display the image. You would normally connect this to a 12v reverse wire. The regular power and ground connections still need to be made. If you connect the trigger wire to a constant, the camera image will be on all the time. You would have to break that connection to return to the NAV display.
Old 11-26-2012, 12:15 PM
  #97
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I kind of figured that.
I have designed a circuit depending on what the voltage reading is across the ORG/WHT wire and the black ground wire.
Old 11-26-2012, 01:32 PM
  #98
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
OR I could have a push button switch connect in line with the blue wire (which would be connected to the RED/WHT cigarette lighter adapter wires), that, when I push it momentarily closed, it would show me the camera based on a three way toggle switch (whether the toggle switch is center, left, or right). That's the way the new Accord has it becauses being connected to the turn signal.
Old 11-26-2012, 01:53 PM
  #99
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I meant besides being connected to the turn signal wires.
Old 11-26-2012, 05:37 PM
  #100
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
So I took out the turn signal relay under the dash and tested pins 4 (left positive) with pin 1 (ground). It measured 10.59V, and the multimeter stayed a consistent 10.59V. It's pretty close to the +/- 10% needed for the 12V of the camera, so I'm going to put the plus camera wire on pin 4 and the negative on pin 1 without the relay in and connect the video wire to a TV to see if the camera powers on when the turn signal is activated. If it is, my next problem will be how to tap into pins 4 and 1 WITH the relay in. But at least the video camera will work!
Stay tuned!
Old 11-26-2012, 07:04 PM
  #101
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
It works! It works!
Holy crap! It works!
I took out the turn signal relay, connected the camera positive wire to pin 5 and the camera negative wire to pin 1, turned on the car and turn signal, and connected the camera to a small TV, and it works!
Now I have to see if the 10.59V at those pins is enough voltage to turn on the NAVTool unit via the blue wire. We'll see...
Old 11-26-2012, 08:39 PM
  #102
TL-S
quanaman's Avatar
Awesome!! I'm excited to see this!
Old 11-26-2012, 09:10 PM
  #103
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I am too!
I was a little concerned because my left-hand camera would not turn on, even after being connected to a 12V battery. I think it's dead. No matter, it was only $17 off eBay (the third link from the first post).
Old 11-26-2012, 10:57 PM
  #104
crazyasiantl's Avatar
Old 11-27-2012, 02:58 PM
  #105
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
They don't make fusetaps for the relays shown in post #95, so I bought some 7/64" male/female spade connectors and plan on modifying the circuit to add the camera power wires.
Old 11-27-2012, 07:53 PM
  #106
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I routed the right camera power wire to the left side just now. Took about 15 minutes because I wanted to zip-tie the wires.
I get the NAVtool box (thanks Mugen-K!) on Thursday, and in anticipation of getting it, I'm going to take out the right-side trunk lining and the rear seat tomorrow afternoon to route the wires that I need to the front (switch and the blue trigger wire).
The hardest part left is trying to tap into the relay box somehow. I'm modifying some spade connectors to tap into the hazard/turn signal relay. I'll let everyone know how it goes!
Old 11-28-2012, 05:55 AM
  #107
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
New wiring diagram.
Old 11-28-2012, 06:58 AM
  #108
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
how about just steal a 2013 Honda Accord EX-L mirror and call it a day . I can't wait to see the outcome.
Old 11-28-2012, 07:46 AM
  #109
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
If anyone has the manual for that car, I would like to see how it's connected.
I'll let you know how it goes.
Not only will I post pictures, I'll also post several DIY videos.
Old 11-28-2012, 11:50 AM
  #110
Codename Duchess
Betcha a nickel it is all done through the databus system.
Old 11-28-2012, 12:45 PM
  #111
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Bastards sum bitches.
Old 11-28-2012, 04:27 PM
  #112
Codename Duchess
I ran into some of the same issues when I tried to use my factory camera with an aftermarket radio. Couldn't get it to turn on b/c the power for it is controlled through the BCM. Ended up just punting and using an aftermarket Alpine camera in the same mount.
Old 11-28-2012, 09:13 PM
  #113
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
So I spent about three hours removing the rear seat upper portion and lower portion, routing the two video wires the rest of the way to the trunk, and routing the NAVtool blue wire connection and the cigarette lighter connection to the trunk in anticipation of getting the NAVtool unit tomorrow. I also removed part of the trunk lining. The only thing I have to do it to make the necessary electrical connections for the NAVtool unit and I get to see how this sucker works tomorrow!
I also modified several spade connectors to fit into the old turn signal relay socket. I had to splice three of the six pins of the turn signal relay: pin 1 for ground, pin 4 for the left +12V of the left camera, and pin 5 for the right +12V of the right camera. I took a picture of what I did, but will post it tomorrow when and if this works.
I plugged in the relay again to the spliced connections, and the relay works.
Old 11-29-2012, 06:41 PM
  #114
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Holy balls! It works! Everything is hooked up and it works!
Old 11-29-2012, 07:12 PM
  #115
THTL's Avatar
Yayyyyy. Congrat. Pics and video please.
Old 11-29-2012, 09:05 PM
  #116
HE>i
05_NBP_TL's Avatar
In for pics
Congrats
Old 11-29-2012, 09:15 PM
  #117
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
I'll be posting pics soon, and several videos shortly.
The hardest parts of this project was modifying the spade connectors (not really hard per se, but time-consuming) to fit the turn signal relay, and putting the damn seat back back in the car.
Old 11-29-2012, 09:32 PM
  #118
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Money shot:
Picture of the modified relay:
Pin 1 at the top is the ground, pin 4 is for the left hand positive camera +12V wire and pin 5 is for the right hand positive camera +12V wire. The blue wire needs to be spliced into pins 4 and 5 for this to work.
Old 11-30-2012, 07:20 AM
  #119
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Video to prove it works.
I don't understand why the embed won't work on this!
Old 11-30-2012, 08:28 AM
  #120
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Quick Reply: Small cameras on side-view mirrors
