SIRPAN1 to get sirius?
Old Nov 18, 2006 | 09:04 PM
D&D05TL's Avatar
2006 WDP TL
Ok i have searched for the new SIR-PAN1 device on here but no luck.... but here I go....
The OEM system is made for Acura and ELS by panasonic. There is a new sirius tuner out to work with new Panasonic radios...
HTML Code:
http://www.bhphotovideo.com/bnh/controller/home?A=details&Q=&is=REG&O=productlist&sku=439901
I think I may pick one of these up and see if I can make it work....please feel free to comment...I will post results ASAP
Old Nov 18, 2006 | 09:12 PM
D&D05TL's Avatar
2006 WDP TL
sorry im a noob
http://www.bhphotovideo.com/bnh/cont...ist&sku=439901
Old Nov 18, 2006 | 10:20 PM
lembowski's Avatar
Trucki!!
but do you think the plug they are reffering to is on panasonic aftermarket units, and not factory systems
Old Nov 19, 2006 | 07:05 PM
D&D05TL's Avatar
2006 WDP TL
I am pretty sure it is designed for the new aftermarket headunits but I am hoping that Panasonic used the same bus so that maybe just maybe I can replace the OEM XM tuner with the SIRPAN1 and have sirius in the TL
Old Nov 19, 2006 | 07:57 PM
revo's Avatar
Back in the saddle..again
Actually I am sure it is for the aftermarket Pana headunits. As for the OEM headunit I am not sure if it uses the same BUS...need to look at the connectors. Also the antenna is different for XM and Sirius.
Old Nov 19, 2006 | 10:29 PM
Knertified's Avatar
I thought our OEM system was Alpine?
Old Nov 20, 2006 | 01:52 PM
D&D05TL's Avatar
2006 WDP TL
Nope...definately Panasonic:
http://www.elssurround.com/ELS_surround.asp
Old Nov 29, 2006 | 09:17 AM
vector1701's Avatar
So will this work? Anyone call the company to see if it is Acura compatible?
Old Jan 2, 2007 | 12:13 AM
denmoses's Avatar
I tried calling Acura, but the person i talked to could not help. Just wondering if anyone has pursued this option ? is it possible ?
Old Jan 2, 2007 | 04:54 AM
triggle's Avatar
'04 6mt Pearl
This is worth investigating more thoroughly. If it works it opens the door to add all sorts of devices with the Panasonic CY-EM100U Expansion Box.
Crutchfield has the SIRI-PAN on sale for 79$. They also have a PDF installation manual on the Hands-on Research tab under "What's Included". The PDF shows a 2 pin Panasonic data bus.
http://www.nextag.com/sirius-sir-pan1/search-html
http://www.crutchfield.com/S-GnN1KFB...607SIRPAN1#Tab
koju01
ILX Audio, Bluetooth, Electronics & Navigation
Dec 14, 2015 02:17 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
mgbe11
1/2G MDX (2001-2013)
Sep 15, 2015 07:53 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
