Shark Fin antenna on 3rd Gen TL
Old 12-18-2015, 01:36 PM
JPerkMr954's Avatar
Not sure where to post this question, and my research didn't get me a clear answer - How can we use a sharkfun antenna from a 5th gen tlx ilx ect or maybe a lexus on a 3rd gen?
I'd assume that under the base are electronics - which I don't need - but trying to get some more direction about an option that can work...
Old 12-18-2015, 05:51 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I have a sharkfin, I can link you what I bought but it goes over the existing XM.
Old 12-18-2015, 08:02 PM
JPerkMr954's Avatar
PLEASE DO! It's is a complex install? Any issues effecting XM? That's the same color of my TL so even better...
Old 12-27-2015, 11:04 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
You can remove the bubble by removing the rear map lights and then you can access the screws to the bubble rather than removing the whole dang headliner.
JPerkMr954 (12-28-2015)
Old 12-28-2015, 01:15 PM
JPerkMr954's Avatar
I didnt even get that far in this to figure out how to remove it. I'm waiting on the previous post to let me know where he picked his up from!
Old 12-28-2015, 01:28 PM
Joneill44's Avatar
Received 3,594 Likes on 1,720 Posts
Not sure where GP got his from but there are 1000 different styled ones on Ebay. Some have openings for electronics others are dummys with no underneath opening.
Old 12-28-2015, 01:45 PM
Holy smokes, I've been so caught up I forgot about this thread!
Search up "Nextek shark fin" on ebay.
They're all around $30 (on the expensive end for shark fin antennas). I believe they're all universal and the same size so some may say "for Lexus" or "for Oldsmobile" so just pick any one. Probably best to pick a silver one and see if you need to get it painted or not. I had to get mine painted because it was black.
I don't have XM because I'm in Canada but SharksBreath had the same one (I actually bought his extra one off him) and he said he removed the XM antenna and just tucked the antenna into the headliner and still had signal.
Cheers
JPerkMr954 (12-29-2015)
Old 12-29-2015, 01:43 PM
JPerkMr954's Avatar
Cheers
Wouldn't you just need to take off the existing cover and then place this one in its place?
Old 12-29-2015, 03:41 PM
The XM antenna isn't a cover, its a whole assembly with the antenna inside.
Here's what sharksbreath did
https://acurazine.com/forums/photogr.../#post13289176
Old 09-18-2018, 09:12 AM
4th Gear
Mike-Mike's Avatar
Shark Fin Antenna Cover Question
Hi my friend. I love your car. Can you give me the link for the cover you bought for the xm antenna? I bought and painted one and removed the stock antenna only to realize it doesn't come apart. Also, what front lip and rap bumper/lip do you have? I want the same for my car. Please just email me at Mikeandjo2016@gmail.com because I rarely get on here. Thanks!
Old 09-19-2018, 06:37 AM
DMZ
Head a da Family
DMZ's Avatar
JPerkMr954, does the sharkfin antenna provide better XM reception? Where did you get those taillights?
Old 09-20-2018, 09:42 PM
Search up "Nextek sharkfin" on ebay - you place it over the existing XM antenna. A-Spec lip kit all around
You're talking about my car?
Custom tail lights made myself, and no it does not provide better XM
Old 09-24-2018, 06:25 PM
Received 8,594 Likes on 6,638 Posts
No, but I bet it makes your car more aerodynamic
Old 09-26-2018, 05:47 PM
Joecop67's Avatar
How many hp does it add? I gotta get mines.
Old 10-22-2018, 02:30 PM
iTzVlad's Avatar
Thank you for this. I bought my sharkfin shell 2 years ago and finally got around to installing it. Removing the old shell is pretty easy, takes about 5 minutes. There's a few screws and a 17mm bolt. You can use the xm antenna in the new sharkfin shell. It's held on by tape but you could theoretically use the 17mm bolt. I use some 3m tape to keep the sharkfin on, some vinyl wrap over the hole on both sides (just in case of water), heated the tape with a blow dryer for better tape adherence and weighed it down with heavy textbooks for a few hours. Hit 65mph and it stayed on no problems without the bolt. I feel like it's a small mod but if you are going for attention to detail, it's worth it. Gives the TL a more modern look since most eco cars after 2012 have this from the factory.
TaSeX
ILX Problems & Fixes
21
08-06-2020 08:46 AM
DwDrummer
05-19-2018 06:35 PM
losothefatso
12-29-2015 04:14 PM
black2010tl
12-27-2015 10:45 PM
ELDeFontes
12-23-2015 02:37 PM
Quick Reply: Shark Fin antenna on 3rd Gen TL
