Replaced Navigation: Français?
My 06 TL navigation broke (kept rebooting. I suspect it was a memory problem). The dealer replaced with a new navigation system. I noticed two differences:
1) My OK screen now includes a "Français" button. (merci beacoup)
2) I can not get any of the 'XM' voice commands to work.
There are probably more.
Could I have received a Canadian navigation system? If so, is there no XM option in Canada? (Quel dommage!)
I'm asking you first before I take it back to the dealer so I will know the proper resolution.
Thanks,
MG
Thanks,
MG
Sounds like your nav is not set to US mode. It can easily be changed by accessing the "secret" maintenance mode (or whatever you call it). Do this by allowing the nav to boot up, and hit the OK button to enter nav mode. Now press and hold the MAP, MENU, and CANCEL buttons for a few seconds and release. It will bring you into a setup menu. Go to the NAVI SYTEM (the first tab) and it will show a CHANGE to US box. By pressing this on screen button it will change back to US and I think reboot on its own. Then you should lose the FRENCH button on the startup screen and XM should be back.
Good luck,
Mark
Good luck,
Mark
WDP Director of R & D
Originally Posted by mgiles
Fantastic. That was the trick. It's now in the US mode and the XM voice commands work. Also I know how to switch it back so my daughter can practice her Franch.
Merci Mark!
Merci Mark!
I was going to say that the voice commands probably did work initially,,,, you just weren't speaking the right language..
However, one would have thought your dealer would have set it properly for you Next time you see them let them know they missed a step in the R & R process...... Wankers!
Good luck,
Mark
Good luck,
Mark
Originally Posted by CobraGuy
I take it you're from Canada? Otherwise, how in the world could a dealership allow your car out of the shop set up that way!
Originally Posted by italian_spak
yes its the canadian model, get it changed buddy
See post 3 and 4.
cycdaniel
12-17-2019 10:58 AM
rockyboy
01-25-2016 06:00 PM
