Remove factory radio
Old May 15, 2008 | 04:17 PM
gumby430's Avatar
I need to remove my factory radio and navi. Is there as step by step somewhere that will tell me what needs to be done. Thanks
Old May 15, 2008 | 04:25 PM
ernie01acura's Avatar
its real easy dude, pop off your trim and its only a couple screws to take it out, dont be afraid to try it
Old May 15, 2008 | 05:58 PM
KN_TL's Avatar
Ernie, I'd really like to see the process you used that only involved 2 screws!
My TL had a lot more involved.
The silver side trim is removed.
Then the center console is unscrewed.
In the manual, both side panels are removed which also means removing the lower part of the drivers side and the entire glove compartment. I only remove the drivers side.
Then the compartments below the radio has to have all the screws removed and just snapped out of the bottom of the head unit.
The top vents/display unit is removed.
Screws to the HU/display are removed.
Unplug everything, then the unit comes out.
Old May 15, 2008 | 08:28 PM
King of Pain's Avatar
I agree, this is major surgery. Trust me, I've done this plenty of times.
Old May 17, 2008 | 12:40 AM
datmrman's Avatar
Along with the 3G Garage I gave you a link to in another thread gumby430, there is also this thread: 3G TL Audio & Electronics FAQ. You'll find links to instructions there. Good luck!
BoricuaTL
Apr 8, 2016 01:08 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
scionxb3003
Oct 2, 2015 05:50 PM
pistacio
Sep 26, 2015 09:45 AM
