Rear fill, stationary vs driving.
I know no rear fill is the best for SQ while youre sitting there with the engine off and car parked. I've had my rear speakers disconnected for a long time and recently got bored and hooked them up. While driving, with the rears just loud enough to tell they're on, they seem to cover up a lot of the road and tire noise back there. I would almost say it sounds better with just a little sound back there with the car in motion.
Anyone have opinions on this, primarily the SQ oriented guys? It's definately louder this way.
PCM full of water, yummy
TL owner
I think its a catch 22 because i totally agree that it will be louder and cover more inside the car with rear fill. I think that depending on your front stage set up and amplification u can get away with just components up front but in a real world driving situation and wanting volume id go with rear fill. Thats kinda where im at myself wondering if i want to do rear fill. My other car is a 4 door 92 h22a-t accord and my last car was a 2003.5 mazdaspeed protege' that i traded in for my TL and both are kinda small compared to the TL so just running a front stage was ok. Ive used the 3sixty.2 on a few customers cars and Ill be running a 3sixty.2 in my car and depending on if I run my component in active or not i might just mute the rears if i do a comp and turn it them back on for normal driving. I think if the front stage is tuned well and time alignment is set correct that a lil rear fill cant hurt for normal driving just for added volume.
R you worried about road noise or getting good quality sound?
Internal resonances and road noises can be corrected with the right amount of damping material in the trunk, doors, rear shelf and under/around the rear seat area.
It really comes down to what you like and what is acceptable to your ears.
Fearless DIY Guy
Well...the real catch 22 is as follows: your front sound stage should be comprised of QUALITY components with equally as capable power source to match. Should this notion be followed, your assertions, at present, would stand otherwise.
I'm not lacking power as others can attest to. I don't want to have to listen to it at insane levels to drown out the rest of the noise. I'm very pleased with the sound quality too. To get any better than these would require a lot more money which I'm not willing to spend just yet.
Not where I should be
I'm thinking of letting the stock amp run the rear fill, while running the front doors through my Cleansweep to my aftermarket amp. I figure if it sounds like crap I can always remove the rears or replace the speakers with better units and power off the same aftermarket amp, but I'd rather us that power for the fronts only. I want to avoid getting a second amp.
Fearless DIY Guy
CheeseyPoofs McNut
10-11-2015 11:25 AM
oyayjoe
09-12-2015 04:40 PM
