RCA adapter for subwoofer?
Old Aug 16, 2011 | 11:46 AM
nsxxtreme's Avatar
I want to put an aftermarket subwoofer in my 04 TL. Is there a line level adapter or something that connects off the stock stereo or amp that will give me RCA outputs for the sub?
Old Aug 16, 2011 | 11:47 AM
a Line out converter.
Old Aug 16, 2011 | 12:06 PM
geekybiker's Avatar
Just disconnect the sub in the truck and LOC the speaker line in there. Super simple. Make sure you get a good LOC. Cheap ones act as a highpass filter.
Old Aug 16, 2011 | 03:51 PM
Trunk Monkey's Avatar
Coolest A-zine Member
Are you adding speakers or anything?? If that's the case, might as well get an Audiocontrol unit like the Matrix or a processor for cheap. Especially if your taking pre-amp signal
Old Aug 17, 2011 | 08:57 PM
nsxxtreme's Avatar
Do you guys know where the stock subwoofer amplifier is located? I really don't like the idea of using a LOC. If I can locate the stock amplifier I could probably just tap into the low level input.
Old Aug 17, 2011 | 09:18 PM
sddale's Avatar
It's in the passenger kick panel. You'll have to take out the glove box and the panel above the passengers knees. It's pretty easy...just search for the thread on it for all the info.
Old Aug 17, 2011 | 09:32 PM
Passenger kick panel. Very easy to get to. No need to take the glove box off though. I didn't/don't. Wonder how much space it gives though. Hm
Old Aug 17, 2011 | 09:34 PM
Btw..our pre-amp signal is super low (balanced) and our post-amp is super high (balanced)
Old Aug 17, 2011 | 11:18 PM
sddale's Avatar
You don't HAVE to remove the glove box but it gives so much more space to work it's silly not to. It takes 3 min to do...2 screws 2 pins and a some tugging.
Old Aug 18, 2011 | 12:28 AM
geekybiker's Avatar
I can get into that panel in about 3-4 seconds now.
kb1rl
Sep 30, 2015 10:17 AM
SeaJay
Sep 30, 2015 09:15 AM
ceb
ILX
Sep 27, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
