Rattle from tail lights
06 WDP/Ebony MT NAV ASPEC
I have a w3 corner mount box running off two channels of a PDF f6, I have deadened the whole trunk and the only place left rattling are the taillights from what I can tell. I can't hear it inside but I can see them move and hear them from the outside easily. Has anyone had a similar experience ? Is there a solution ?
That's odd. I run an infinite baffle setup which uses the trunk as the "enclosure" with a pair of 15s and no rattles from the tail lights. No rattles when I had the pair of 12W6s on 1,200w either. I would start with checking that the lenses are tight, Also make sure it's not the vents between the trunk and outside.
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
wusty23jd
09-24-2015 11:41 AM
